RC300 - rc-300 mic in -> sub-out?
Started by looper, June 13, 2014, 01:54:55 PM
looper
Is there some form of voice (mic-in) to be heard, without being recorded along with the guitar?
The sub-output only works for tracks?
geormiet
Ive been trying this forever, theres no way.
You can get a 2nd rc300 and sync up with midi.
looper
Quote from: geormiet on June 13, 2014, 06:53:22 PM
I think not need as much.
then I believe that a behringer 1202 solve, by using the external effect.
Ie connecting each instrument in the mixer to send to rc-300 via exit fx. As the microphone is not sent (send = 0)
And a second microphone with shipping for rc-300 for when you want to record the voice loop.
Then just return the rc-300 in another mixer channel.
I did this with an ipad and LoopyHd and worked well.
There are other possibilities as well, depending on the equipment available.
Just thought rc-300 could do it alone.
No, the RC300 mixes its three sources (inst, mic & aux) & basically treats them as ONE input signal.
Too bad, that one enhancement would make it dramatically more flexible.
sjrb
looper
