Micro BR-80 eBand songs
Started by gumtown, October 03, 2011, 02:01:55 PM
**IMPORTAINT NOTE** I recommend backing up a copy of the files contained on the SD card which comes with your Boss BR-80, the drum loop tracks  and demo song are not backed up or downloadable from anywhere else.
If you erase the card, the factory material is gone for good.
I have decided to also use my Boss Micro BR-80 as my every day MP3 song player, so i have loaded up much of my favourite material, songs to listen to while on the road, and songs to play during gig set breaks. Also all my practice songs which on the current gigging setlists.
To load the songs in the eBand Song editor must be used, the song formats must match those on the compatibility list, or the eBand editor will reject them.
Now this is the bit that had me stumped for a while, the song file attributes must be correct and complete, in particular, the song Album, Title, and Song Artist, as well as the file name. I noticed this when trying to load my playlist songs in alphabetical order, but they were listed in the BR-80 in a seemingly random order, this is why...
The BR-80 can group or organise songs by either Artist or Album, if these attributes were empty, then the list will be full of blanks.
The BR-80 does not organise by file name, but by the file attribute song name.
To check the file attributes before using eBand editor (in windows), right click on a song file and select 'properties', from there you can edit the attributes as required.
A group of files can be selected and have the common properties edited, like Album and artist as a group setting.
When a song is played, the original file name is displayed on the screen as the song title, not the file attribute 'song title' setting.
With the file attributes set before using the eBand song editor to load material into the BR-80, organisation of songs by Album and Artist in the BR-80 make your experiance much more enjoyable, the BR-80 will play a continuous list of songs by the catagory you have chosen.
IF YOU HAVE ERASED YOUR SD CARD WITHOUT SAVING THE CARD DATA,  :'(
YOU CAN DOWNLOAD IT FROM HERE:
MICRO BR BR-80 factory installed data in the included SD Card
This is a file for recovering factory installed data in the included SD Card.
http://www.roland.com/support/article/?q=downloads&p=BR-80&id=62223191
<< MICRO BR  BR-80 SD Card >>
This SD card contains software that will help you get the most out of your BR-80.
- Win.zip
This is a compressed file that contains drivers and applications to be used with Windows.
Expand this file on your computer, where you can then make use of the files it contains.
- Mac.dmg
This is a disk image file that contains drivers and applications to be used on a Mac.
After expansion you'll see the following folders
- "Drivers" and "x64Drivers" folders
This contains USB drivers designed specifically for the BR-80. They allow you to use the
BR-80 as an audio interface after you've connected it to your computer using a USB
cable.
For details on each driver and up-to-date information, please read the relevant
"Readme.htm" file, which can be found in the folder containing the driver you're using.
Make sure to read this file.
- "Song List" folder
Here you'll find the software needed for adding songs to the BR-80's eBand mode, or for
editing a song's performance data.
For instructions on how to install the software, please read "ReadmeJP.txt," which
can be found in the "Song List" folder.
- "Wave Converter" folder
Here you'll find the wave data that's been written to the tracks in the BR-80's MTR
mode, and software that can be used to perform bidirectional file conversions
(BR Series Wave Converter).
For instructions on how to use the above, refer to the manual that can be found in the
"Wave Converter" folder.
# Contents of this SD card
[BR-80 eBand]
+- ReadmeEN.txt: This document
+- ReadmeJP.txt: Japanese version of this document
+- BR-80_DataList_j.pdf: Data List
+- BR-80_DataList_e.pdf: English version of Data List
+- [Win.zip]
|    +- [Drivers] : 32-bit Windows versions of the USB driver
|    |     +- [XP] :    Windows XP version of the USB driver
|    |     +- [Vista] : Windows Vista version of the USB driver
|    |     +- [Win7] :  Windows 7 version of the USB driver
|    +- [x64Drivers] : 64-bit Windows versions of the USB driver
|    |     +- [Vista] : Windows Vista x64 version of the USB driver
|    |     +- [Win7] :  Windows 7 x64 version of the USB driver
|    +- [Song List] : eBand Song List Editor for Windows
|    |     +- Setup.exe : The installer for the eBand Song List Editor
|    |     +- ReadmeJP.txt : Instruction manual for eBand Song List Editor
|    |     +- ReadmeEN.txt : English version of eBand Song List Editor's instruction manual
|    +- [Wave Converter] : Wave Converter for Windows
|          +- BRWC.exe: The executable file for Wave Converter
|          +- BR_Wave_Converter_Manual_Win_J.pdf: Instruction manual for Wave Converter
|          +- BR_Wave_Converter_Manual_Win_E.pdf: English version of Wave Converter's instruction manual
  +- [Mac.dmg]
|    +- [Drivers] : Mac OS X version of the USB driver
|    |     +- OS X 10.4,10.5,10.6 version of the USB Driver
|    +- [Song List] : eBand Song List Editor for Macintosh
|    |     +- eBand Song List Editor Installer.mpkg :
|    |     |      The installer for the eBand Song List Editor
|    +- [Wave Converter] : Wave Converter for Macintosh
|          +- BRWC : The executable file for Wave Converter
|          +- BR_Wave_Converter_Manual_Mac_J.pdf : Instruction manual for Wave Converter
|          +- BR_Wave_Converter_Manual_Mac_E.pdf : English version of Wave Converter's instruction manual
+- [ROLAND] : Data for MTR mode / eBand / LIVE REC mode
In order to read the PDF files you will need to have Adobe Reader(R),
which can be obtained free of charge from Adobe Systems, Inc.
# IMPORTANT NOTES
- In the interest of product improvement, the specifications and/or contents
of this package are subject to change without prior notice.
- Microsoft ,Windows and Windows Vista are either registered trademarks or
trademarks of Microsoft Corporation in the United States and/or other countries.
- Windows is known officially as the Microsoft(R) Windows(R) operating system.
- Mac OS is a trademark of Apple Inc.
Copyright (C) 2011 BOSS Corporation
This document, the content of the files contained within this DVD, and any
other materials cannot be modified, copied, distributed, or reproduced
without the permission of the BOSS Corporation.
Jeremy Hall
I received the BR 80 today but would appreciate some help from someone please ???
It was still on firmware 1.02 so I updated it to 1.06. All ok so far.
My main use will be for eband mode so I went to eBand mode and selected SONG --> All Songs and was greeted with an empty list :(
I have downloaded the factory disk image from the ftp site above and tried copying over the files to a clean formatted SD card (formatted in the BR 80).
I still don't see any songs in eBand mode.
The zip file from the ftp site contains two folders:
1. MICROBR which contains:
--MP3 folder containing BigDance.mp3
and
Roland folder containing:
--BR0 folder containing:
------CARDPRM.BR1
------DISKINF2.BR0
------SONG0000.BR0 folder containing
-----------ARRANGE3.BR1
-----------EFFECTS3.BR1
-----------SONGINF2.BR0
-----------SONGPRM.BR1
-----------TAKE_DAT.BR0 (this file is about 20Mb so I assume contains the songs??)
-----------TAKE_DT1.BR0
-----------TAKE_DT2.BR0
-----------TAKE_EVT.BR0
and
2. MICROBR_ORGINAL_FACTORY_DATA folder which contains another MICROBR folder with a similar structure to above but the SONG0000.BR0 folder only has a single small ARRNGE3.BR1 file.
From this I assumed that the first MICROBR folder was the correct one to use to reinstate the eBand songs. So I copied the contents of the BR0 folder shown above to the newly formatted SD card's BR0 folder overwriting the diskinfo2.br0 file in the process (maybe this was the wrong thing to do?). Still no luck.
Any help would be much appreciated. Thanks in advance.
Jez
You will require the Roland eBand Song List Editor
Separate versions for Windows or Mac
Important  - the Boss Micro BR BR-80 falls under the Roland Product Category called:
"eBand Gears"
All Roland references to "eBand Gears" in all Roland / Boss product documentation and Workshop Docs refer to ALL the Boss eBand products,  which include these :
* Boss Micro BR  BR 80
* Boss JS-10
*  Boss JS-8
To load songs into Boss BR-80, you need to:
1) Install the BR-80 USB Driver
2) Connect the BR-80 via USB to your computer
3) Launch Roland eBand Song List Editor Application. This requires you to setup the USB connectivity to your BR-80 before it works
4) Use the Roland eBand Song List Editor Application to import and create your eBand songs. To load the songs in the eBand Song editor must be used, the song formats must match those on the compatibility list, or the eBand editor will reject them.
Read all the Roland support docs that explain this whole process
http://www.roland.com/support/article/?q=manuals&p=BR-80
http://lib.roland.co.jp/support/en/manuals/res/62152350/eBand_Song_List_Editor_e02.pdf
And download ALL the BR-80 Workshop guides created by Roland US
http://www.rolandus.com/products/details/1167/support/
http://cms.rolandus.com/assets/media/pdf/BR80WS01.pdf
http://cms.rolandus.com/assets/media/pdf/BR80WS02.pdf
http://cms.rolandus.com/assets/media/pdf/BR80WS03.pdf
http://cms.rolandus.com/assets/media/pdf/BR80WS04.pdf
http://cms.rolandus.com/assets/media/pdf/BR80WS05.pdf
Jeremy Hall
Blimey! Thanks for your help.
Am I correct in saying then that the songs are on the sd card in the br80 but you need to use a windows utility via usb to tell it that they are there?! How strange.
Thanks anyway,
Jez
If your BR-80 was fresh new out of the box, you pop the factory Roland SD card into the slot, and read the owners manual and try of the eBand functionality using the Roland demos.
Read the BR-80 Owners Manual  eBand function are described on Page 28
http://media.rolandus.com/manuals/BR-80_e05_W.pdf
Jeremy Hall
Quote from: Elantric on June 12, 2013, 12:21:34 PM
Yes that's what I am hoping to achieve i.e. to get the SD card back to the state it was in when the BR80 was new. I just thought it would be easier than the process described above.
Jez
Jeremy Hall
Hi Elantric,
I have completed steps 1 to 4 but now I think there must be a misunderstanding. I now want to restore all the Roland demo songs that would have been on the BR80 when it was new.
Where do I get all these files so that I can achieve this using eBand Song List Editor?  From the demo videos on YouTube there seems to be hundreds of these and they looked quite good.
Maybe someone who still has all the Roland demos can just upload an img file of their SD card? Wouldn't this work?
Thanks and sorry for any confusion
Jez
Try this
QuoteTAKE_DAT.BR0 (this file is about 20Mb so I assume contains the songs??)
On mine - the "TAKE_DAT.BR0" file is 77,280kb = about 72Mb
Jeremy Hall
Nice find! I will definitely try this.
Thanks very much
Jez
Jeremy Hall
Quote from: Elantric on June 12, 2013, 01:40:12 PM
Try this
It worked!
Thanks so much for your great help Elantric ;D
Now I'm off to explore some of these great demo songs...
Jez
Glad to hear you are up and running with eBand on BR-80 now.
Jeremy Hall
Quote from: Elantric on June 12, 2013, 04:06:27 PM
Yes it's all working great now, thanks again.
Incidentally the procedure worked fine on a new 16Gb SDHC card so there is now plenty of room for other songs, compositions etc.
Cheers
Jez
You may notice the larger the SD card, the longer the BR-80 takes to startup.
Jeremy Hall
#16
Quote from: gumtown on June 13, 2013, 04:20:35 PM
Yes it seems to take about 30 seconds to startup with the 16Gb card containing all the demo songs. I'll restore the old 2Gb and see how long that takes.
EDIT: With the 2Gb card it takes about 12 seconds to boot up. Quite a difference, in fact I'll stick with the 2Gb card until I need the extra space, thanks gumtown.
Jez
