BR-80 - Recording a keyboard in stereo into BR-80
Started by hobbytoy, November 09, 2012, 10:57:16 AM
hobbytoy
Hello.
I am just a little curious to know if it is possible to record a stereo keyboard into micro BR-80? Can I use that line-in ministereo plug connection or should I use a stereo jackplug into guitar input?
Thanks for replies.
The guitar in is mono and passes through the effects chain, the mini line in goes direct to the A/D conversion for dry/direct recording, keep the recording level control at a minimum on the BR-80 to prevent noise from the effects DSP bleeding in.
You will need to adjust the keyboard output level for an optimum recording level.
hobbytoy
Thank you very much Elantric and gumtown for the inputs here.
Piing
Hi.
When I try to record through the Stereo Line Input (connected to the Ax-FX II line output), the built-in microphones are automatically activated and it records both the Aux Input and the Microphones at the same time.
The switch at the back side of the BR-80 is set to GTR, not to MIC.
When I just play, in any of the 3 modes, it is OK: I only hear the Aux Input. But as soon as I press the REC button, the MIC is activated.
How can I disable the MIC for recording?. I can't find that option  ???
Piing
Gumtown, I have just seen the other post where you explain the solution:
https://www.vguitarforums.com/smf/index.php?topic=4635.0#msg31265
As a matter of fact, I was sorting the problem by inserting an amplifier block at the FX chain with the volume set at 0. Now I clearly understand what is happening
Thank You!  :)
