GR-55 - Red LED function Exp Pedal SW problem
Started by Max-bc, June 26, 2016, 09:03:29 AM
Max-bc
Hi,
I wonder why the red LED function Exp Pedal / SW on / off is switched on and off at random and at different times.
Where can I set up correctly?
Is this on a specific patch or on all patches? If it is one patch, please post it. It could be a double assignment.
Max-bc
Quote from: sixeight on June 26, 2016, 09:08:40 AM
All patches
Testing this
https://www.vguitarforums.com/smf/index.php?topic=3868.msg26449#msg26449
thanks
The expression pedals switch id operated when pushing down the expression pedal. It should only switch when you press hard. If it switches too easy, you should recalibrate the expression pedals.
This could be your issue:
https://www.vguitarforums.com/smf/index.php?topic=9491.0
And this the solution :
https://www.vguitarforums.com/smf/index.php?topic=9857.0
