VG-88 Normal Guitar Effect Loop Mod
Started by Elantric, March 31, 2014, 12:59:23 PM
Next time you are debugging "why can't I hear my Normal PU's in my VG-99 / GR-55 / GP-10 using one 13 pin cable   - be sure nothing is connected to the 1/4" outputs jacks
Just wanted to point out that Godin LGXSA and xtSA 1/4" Output jacks feature the similar circuit as the Fender Roland Ready / GC-1 Strat below.
the Fender Roland Ready Strat / Roland GC-1 Strat's 1/4" output jack is a unique switching jack - The goal is to have a "stock Strat" when using the 1/4" output jack  - so anytime you insert a 1/4" plug into the GC-1's 1/4" "Normal PU Output"  jack  - this isolates removes the normal passive Strat Electronics signal output from entering into the GK Internal active buffer (which might load down the passive PU's and reduce high frequencies) and removes the ability to send normal mag PU tone down Pin #7 of the 13 pin Cable
FWIW - the detailed VG-99 external FX loop mod is described here:
https://www.vguitarforums.com/smf/index.php?action=downloads;sa=downfile&id=87
VG-99 - DIY Mono FX Loop Insert for Normal Guitar PU feed
https://www.vguitarforums.com/smf/index.php?topic=474.0
Spacemuse
Quote from: Elantric on March 31, 2014, 12:59:23 PMVG-88 Normal Guitar Effect Loop Mod
Hello, with such a mod does the unit work exactly as before if just the guitar in is used with no gk? It seems it does, except for guitar out no more mirroring, but just to be sure..
Guitar In ( now FX Return) should work
