Dark Fire Hex Piezo > Re-amp on VG-99 !!! ... And Variax ???
Started by mikelange, September 27, 2015, 04:14:37 PM
mikelange
Hi.
This is my first post ever. I hope it's in the right place.
I've managed to re-amp my Darf Fire's Hex piezo pickup, with two pro custom made cables, basically like this :
(see attached image : Dark Fire Hex pickup re-amp on VG-99.jpg).
I would like to do something similar to re-amp my Variax JTV69 piezo pickup, basically like this :
(see attached image : Variax piezo pickup re-amp.jpg).
Is it possible ?
Thanks for your help.
The Dark Fire has separate string outputs - with the MiniDIN jack on the RIP box
( details here:)
https://www.vguitarforums.com/smf/index.php?action=downloads;sa=downfile&id=80
the Variax lacks a separate string output connection jack
read about Gk13 pin Break out boxes here
GK Acessories
https://www.vguitarforums.com/smf/index.php?board=13.0
and here
VGuitar Forums > For Sale > GK Pickups / Tools / Accessories
https://www.vguitarforums.com/smf/index.php?board=174.0
mikelange
Thanks Elantric. I've checked those.
Do you know what are the two black cables in the JTV-69 piezo 8pin connector below ?
Let's say I build a kind of "8pin to 6x balanced Jack" 10 feet adapter (not a GK adapter).
If I use this adapter to connect my Variax piezo pickup directly to my audio interface inputs, will I be able to record the JTV's hex signal ?
And if so, if I use this adapter to connect my audio interface outputs to directly into the Variax mainboard, will I be able to playback my recorded hex track into the Variax ?
The [red, white, yellow, yellow, white, red] cables below are obviously e,B,G,D,A,E.
But the two black ones, I don't know... Ground ? Voltage ?
Thanks again for your help.
You'll have to explore on your own
The dual cables are Tyler Variax  piezo saddle signals ( and I lack a schematic , only Line -6 Service Centers have those )
