GP-10 - Anybody smarter than me ever figure out the missing Slow Gear problem?
Started by Rhcole, October 25, 2016, 04:12:20 PM
Rhcole
When the GP-10 first came out I noted the significant omission of the Slow Gear effect. It significantly limits many of the synths and also the modeled guitars as far as useful synth and modeling effects. I revisited this recently, trying to mimic the Slow Gear with reverb and echo delays. Not a very good result.
Anybody else figured a way to fake this effect?
Yes, I know the foot pedal can do this and also the Osc synth. I'm looking for a hidden knob in one of the FX or something.
Anybody?
carlb
The closest I've found is the fretless model. The attack control does a bit of the slow-gear, and on a per-string basis.
Drives an EHX Key 9 and C 9 really well, probably other EHX pedals too.
Morningstar MC8 & MC6
QSC CP8 powered speaker
Rhcole
Hey, that's a good suggestion CarlB, I'll give it a try!
Why no pitch shift for Wave synths or Slow Gear, c'mon Roland.
But that's just the way they roll.
carlb
Hmmmm. Apparently, the Poly-FX of the GP-10 has a per-string slow-gear option, too. Might be more "slow" than the fretless model. I haven't had a chance to try it yet.
I don't like the slow gear poly effect of the GP10.  It adds some pitch shifted harmonics that do not sound right to me.
I did get a better result with the OS synth: https://www.vguitarforums.com/smf/index.php?topic=15081.msg107776#msg107776
Rhcole
Carlb,
I don't see the Slow Gear for Poly FX- could you share a screenshot?
I suspect he means Poly FX:  "Slow Pad"
Quote from: Elantric on October 29, 2016, 11:28:23 AM
Yes,  that is the one. I never use it,  so I forgot what it was called...
Rhcole
Sure, the Slow Pad is REALLY slow but you can't change its attack. Sixeight I like your string patch. You can change harmonics in the Slow Pad somewhat FWIW.
Or you could always swell into every note with your GK Volume knob.  Lots of manual effort but....
How about a stab at a CTL pedal to instantly minimise the level and have it rise slowly back to normal.
Using an assign, with Internal Pedal, triggered by CTL, with a slow rise curve, controlling patch volume or normal PU level,
or if you are daring, control the amp gain.
Kenmac
I realize this is primarily hardware related but if you do use the GP-10 with your Mac or PC there's a free plugin available called "AutoSwell Light" in VST and AU format which does a great job of simulating the Boss slow gear pedal. You can check it out here: http://pechenegfx.blogspot.ca/2015/06/autoswell-light-new-audio-effect-in-vst.html
roachone
Went to download, my security says there is a computer virus in this download. BEWARE!
Kenmac
Quote from: roachone on January 12, 2017, 06:03:34 PM
I think you're getting a false positive. I've been using this plugin for awhile now. Which anti-virus software are you using?
roachone
avast. ok, seems nobody has a fried computer yet, so I'll try it. Thanks
N01seMaker
My solution to this problem was to drag out my old Line 6 DL-4 and use the Auto-Volume Echo mode in 3 different patches to give me 3 different attacks (quasi-fretless, cello-ish, new-age-synth). I wasn't able to find anything on the GP-10 that measured up to the old COSM Slow Gear model on my ancient GT-6, unfortunately.  :(
Rhcole
Conclusion several months later- GP-10 can't do it won't do it nah nah nah.
nix808
it sounds like you need a hexaphonic auto-wah,
but on volume, not frequency.
Otherwise, any synth has attack?
Just going by you guys talking about this sound
Rock and Rock my boat, as long as you don't rock and rock my boat!hehe
