Boss GT-10 USB question - computer not seeing it...at all!
Started by Starscream, May 10, 2016, 09:22:21 AM
Starscream
Hey, y'all!
Here's a scenario that maybe you can help me with...please!  lol
I've got the Boss GT-10, and here's the deal...
First off, yes, I've been to the support page, yes, all instructions have been followed, etc, etc.  My problem is, my PC isn't even 'seeing' the GT-10 when plugged in via USB any more. I've uninstalled, and reinstalled the driver.  Three times now.  But even still, you'd think if I simply connected the darn thing, the PC would at least recognize that "something" has been plugged into the USB port.  Not even a whimper of recognition. Nothing.
Yes, I've tried different USB cords, Yes, I've rebooted. Yes, the driver setting on the pedal is set to advanced...all the normal stuff.  It's so weird.  It worked before, but now...nada.
Thanks much.
If you randomly try different USB ports on your computer for the GT-10 connection, You will clobber the Roland GT-10 USB driver .
if you are running Windows 7 or less , You should try the Roland Cleanall utility
http://www.roland.com/support/by_product/v-synth/updates_drivers/1702
then identify your operating system and download the GT-10 USB driver - but this time carefully read the USB driver Installation instructions - contained in the "README.htm" file
And label the USB 2.0 port on your computer that you used when installing the GT-10 USb Driver, and always use that same physical port.
If your computer only has USB 3.0 ports - you might need use a different computer that still has USB 2.0 ports
http://www.bossus.com/support/by_product/gt-10/updates_drivers/4066
Here are the crucial USB Driver installation instructions most folks never read -   "README.htm" file, contained in the Boss USB Driver *.zip file
GT-10 Driver Ver.1.0.0 for Windows® 7 64-bit Edition
(Note)
In no event shall Roland Corporation ("Roland") be liable to end-users for any damages whatsoever, including but not limited to financial damages for loss of business profits or business information arising from the use of, or inability to use this product. The foregoing provision is effective even if Roland has been advised of the possibility of such damages.
*   All files and other material contained in this folder are copyrighted by the Roland. Any alteration, modification, duplication, distribution, or reproduction of this material is prohibited. Additionally, Roland reserves the right to make changes to these programs and files without prior notice.
*   Microsoft and Windows are registered trademarks of Microsoft Corporation.
*   ASIO is a trademark of Steinberg Media Technologies GmbH.
*   All product names mentioned in this document are trademarks or registered trademarks of their respective owners.
About this driver
This is the GT-10 driver for Microsoft® Windows® 7 64-bit Edition.
This driver also supports ASIO(Steinberg Audio Stream I/O Interface) 2.0.
System requirements
This driver has the following requirements.
Operating System
*   This does not work with the 32-bit Edition of Windows 7.
Computer
A computer with a USB connector that supports USB Specification Revision 1.1 or higher
*   This driver cannot be used in a virtual Windows environment, such as Windows XP Mode (Virtual Windows XP) or Virtual PC.
*   Macintosh computers running Microsoft Windows are not supported.
Caution when using the Windows 7 64-bit Edition
In order to use this product with the 64-bit Edition of Windows 7, please read and understand the following points. You must also take into account the compatibility of each product you will be using.
In order to use the 64-bit Edition of Windows 7, you must use 64-bit drivers; not only for this product, but also for all hardware you're using with your computer.
This driver has been tested on several computer systems, but please understand that we cannot guarantee it will operate on your particular computer.
Cautions and Limitations
Sound interruption or other less-than-perfect outcomes may be experienced if your computer's performance and specifications are somewhat inadequate. The types of applications you use and the way in which you use them can also influence the experience you receive.
On some computers, the driver does not load correctly if the GT-10 is already connected when Windows is started up. As a result, it will not be possible to use the GT-10 via USB. If this occurs, wait until after Windows has started to turn on the power of the GT-10 (or to connect it).
If the GT-10 does not work correctly after resuming from Sleep mode, you should exit all applications that use the GT-10, and then turn the power of the GT-10 off and on again.
If the USB cable is disconnected and reconnected while the GT-10 is in use, or if the power of the GT-10 is turned off, then on again, it may stop operating correctly. If this occurs, after resuming, you should exit all applications that use the GT-10, and turn the power of the GT-10 off, then on again.
If your computer was experiencing a heavy processing load, such as when accessing a CD-ROM Drive or network while the GT-10 was being used, the GT-10 may no longer operate correctly. If this occurs, stop the playback or recording, then try starting playback or recording over again. If you are still unable to play back or record, quit all programs that are using the GT-10, then turn the GT-10 off and then on again.
Audio clicks and pops may occur during playback or recording if you connect or disconnect other USB devices (such as USB memory) or turn another USB device on/off while using the GT-10.
In some cases, you may not obtain the expected level of performance if you're using a USB-connected hard disk at the same time as the GT-10. Do not use a USB-connected hard disk as the storage destination for the audio that you're playing back or recording.
Installation
*   To reinstall or update the driver, refer to "To reinstall."
Start up Windows with all USB cables disconnected.
(except for keyboard and mouse)
Exit all applications before you begin the installation.
Double-click the Setup icon.
*   If a message informs you that "Driver installation must be performed by an administrator," you must log on to Windows as a user whose Account Type is Administrator, and then perform the installation.
A confirmation screen regarding User Account Control will appear, click [Yes].
The message "GT-10 Driver will be installed on your computer. ---" will appear. Click [Next].
*   If any other message appears, follow the directions of the message.
Click [Next] to begin installation.
If a dialog box regarding Windows Security appears, click [Install].
The message "Ready to install the driver. ---" will appear.
Use a USB cable to connect the GT-10 to your computer, then turn on the GT-10.
The driver will be installed automatically.
When the "Installation has been completed." message appears, installation has been completed.
Click [Close] to close the "Driver Setup" dialog box.
If the "System Settings Change" dialog box appears, click [Yes] to restart Windows.
Refer to "Before you begin," and make the necessary settings for using the GT-10. You won't be able to use the GT-10 unless you make these settings.
*   If you are unable to use the GT-10 after connecting it, it's possible that a problem has occurred. Refer to "Troubleshooting."
Before you begin
Input/output device settings for your application
In order to obtain optimal performance from your applications, specify the input/output device for your applications as described below. (For details on making these settings, refer to the owner's manual for your application.)
*   Ensure that the GT-10 and the application are set to the same sampling frequency. If the sampling frequency settings do not match, error messages may be displayed and recording/playback errors may occur.
*   If you are unable to select the GT-10 device, a problem may have occurred. Refer to "Troubleshooting."
Audio input/output device
Of the total audio input/output channels provided by the GT-10, there are 2 INs and 2 OUTs
[WAVE OUT Devices]
OUT (GT-10)
*   If you've specified a different name in the "Sound" settings of the Control Panel, the name you specified will be displayed.
[WAVE IN Devices]
IN (GT-10)
[ASIO device]
When using the GT-10 with an ASIO-compatible application, select "GT-10" as the ASIO setting for your application.
*   To prevent an audio feedback loop or double monitoring, make settings on your application to turn monitoring off or use ASIO Direct Monitoring.
*   When using the GT-10 with ASIO, we recommend that you set your application so that it does not use the Microsoft GS Wavetable Synth. (In order to decrease the load, and for convenience when changing Audio Buffer Size of the driver.)
MIDI input/output device
*   In the Windows Media Player, the MIDI input/output device of GT-10 cannot be used.
Please select the following device in your MIDI compatible application.
[MIDI OUT devices]
BOSS GT-10
[MIDI IN devices]
BOSS GT-10
Settings when GT-10 is used with the Windows Media Player
Open "Control Panel," click "Hardware and Sound," and then click "Sound."
*   If the icon view is selected for the Control Panel, click "Sound."
In "Playback," right-click GT-10's "OUT," and choose "Set as Default Device."
*   If the above WAVE ports cannot be selected, a problem may have occurred. Refer to "Troubleshooting."
Click [OK] to close "Sound."
Open "Windows Media Player," select an Audio file, and then play back the file.
To change the settings
To change or verify settings
When changing driver settings, always make sure to first quit all applications using the GT-10. This is unnecessary when only checking the settings.
*   If the Windows monitoring function is enabled, it won't be possible to change the driver settings. Refer to "Could the Windows monitoring function be enabled?" and disable monitoring.
Open the "Control Panel," switch "View by:" to the icon view (Large icons or Small icons), and then click "GT-10."
The "GT-10 Driver Settings" dialog box will appear.
To modify the settings, make the changes and click [OK]. To simply check the settings, be sure to click [Cancel] after viewing the settings.
*   For details on the setting items, refer to "About the items in the Settings dialog box."
Audio Buffer Size
You can adjust the audio input/output buffer size. (By default, this will be the sixth position from the left.)
Decreasing the buffer size will shorten the latency and improve realtime performance, but might make it more likely that you will experience audio clicks and pops, depending on your computer's processing power and the song data load.
Increasing the buffer size will lengthen the latency, but will make audio streaming more stable, and it will be less likely for audio clicks and pops to occur.
In general, you'll probably want to decrease the buffer size for better realtime performance if you're playing a software synthesizer in real time, or if you're monitoring an audio input that's being passed through your DAW software.
Conversely, you can increase the buffer size to prevent audio clicks and pops if you're recording or playing back song data that contains numerous tracks and presents a heavy processing load.
By changing the buffer size as appropriate for your situation, you can obtain the right balance between realtime performance and audio streaming stability.
* Note!
After you've changed the "Audio Buffer Size," make sure to restart all applications which are using the GT-10. Then, if you are using a program that offers a function for testing audio devices, we recommend that you run such tests.
Also, you may want to check to see if your application is one of those that provides a setting for adjusting the buffer size.
ASIO Buffer Size
This is the minimum buffer size that can be set by the ASIO application.
*   Depending on the application you're using, there may be other buffer sizes that can be set in addition to the minimum buffer size, and the buffer size shown here might not match the actual buffer size.
For details on setting and checking the buffer size, refer to the owner's manual for your application.
"Use Smaller ASIO Buffer Size" check box
If this check box is selected, the buffer size when using ASIO-compatible applications will be made smaller.
If you experience pops or clicks when this check box is selected, deselect this check box.
*   You must deselect this check box when adjusting the "Audio Buffer Size."
"Use ASIO Direct Monitor" check box
Check this if you are using the ASIO Direct Monitor function with an ASIO-compatible application.
The "Light Load" check box
Normally, you should leave this check box cleared.
*   The modified setting will take effect after you turn the power of the GT-10 on/off.
"Show README" button
This button displays the README file (this document).
Information
This field shows the driver version.
To reinstall
Delete the driver as described in "To uninstall."
*   When you uninstall, the settings of the Driver Settings dialog box will be initialized. For details on the setting items, refer to "About the items in the Settings dialog box."
Install the driver as described in "Installation."
To uninstall
Exit all applications before you begin the uninstallation.
Open "Control Panel" and click "Uninstall a program."
*   If the icon view is selected for the Control Panel, click "Programs and Features."
In the list, choose "GT-10 Driver", and click "Uninstall/Change."
If a dialog box regarding User Account Control appears, click [Yes].
*   If you are asked to enter the password for an administrative account, log on to Windows as a user whose Account Type is Administrator, and then perform the uninstallation.
The display will indicate "The installed GT-10 Driver will be uninstalled." and click the [OK].
When the message "Uninstallation was completed." is displayed, click [OK] to restart Windows.
Troubleshooting
Cannot install/uninstall the driver
Is the GT-10 set to Advanced mode?
Set the GT-10 to Advanced mode.
Are you logged onto Windows with the appropriate user rights?
You must log on to Windows as a user whose Account Type is Administrator.
*   For more information regarding this, consult your computer system administrator.
Cannot select/use the GT-10 device
Was the driver installed correctly?
If you can't use the GT-10 even though you've installed the driver, the driver might not be installed correctly. Use the procedure described in "To reinstall" to reinstall the driver.
Could the GT-10 be in use by other software?
Exit all applications that are using the GT-10, and turn the power of the GT-10 off, then on again.
If this does not solve the problem, use the procedure described in "To reinstall" to reinstall the driver.
Is the GT-10 WAVE/MIDI device name displayed?
If the device name is not displayed, exit all applications that are using the GT-10, and turn the power of the GT-10 off, then on again.
Did the computer enter a Sleep mode while the GT-10 was connected with its power turned on?
Was the USB cable disconnected and reconnected while the GT-10 was being used, or was the power of the GT-10 turned off, then on again?
If the USB cable is disconnected and reconnected while the GT-10 is in use, or if the power of the GT-10 is turned off, then on again, it may no longer operate correctly. If this occurs, exit all applications that are using the GT-10, and turn the power of the GT-10 off, then on again.
On some computers, if the GT-10 is connected while Windows starts up, the driver will not be loaded correctly, and it will not be possible to use the GT-10 via USB.
If this occurs, start up Windows before you turn on the power of the GT-10 or connect it.
A number such as "2-" is now displayed at the beginning of the device name
Could you have connected the GT-10 to a different USB port?
If you connect the GT-10 to a different USB port, the operating system may automatically add a number to the beginning of the device name.
Even if this occurs, it will not cause any problems with the operation of the GT-10.
*   If you want to restore the device name that does not have this added number, connect the GT-10 to the same USB port as when you installed it, or reinstall the driver as described in "To reinstall."
The screen indicates "Device currently used by another application." and driver settings cannot be made
Cannot playback or record
Did you make settings as described in "Before you begin" so that the GT-10 driver could be used?
The GT-10 cannot be used unless you make these settings. Refer to the sections on "Before you begin."
Could you have entered Sleep mode during playback or recording?
During playback or recording, did you turn the power of the GT-10 on/off, or disconnect and reconnect the USB cable?
If you turn the power of the GT-10 on/off or disconnect and reconnect the USB cable during playback or recording, the GT-10 will no longer be able to play back or record. Stop playback or recording, and then start playback or recording once again. If you are still unable to play back or record, quit all programs that are using the GT-10, then turn the GT-10 off and then on again.
Sound played by your computer is inaudible or too soft
Could you have turned down the volume of the device or application in the Volume Mixer?
The system's Volume Mixer lets you adjust the volume for each device or application.
Open the "Control Panel," and switch "View by:" to "Category."
Click "Hardware and Sound," and then click "Adjust system volume."
The Volume Mixer will appear. From the "Device" pulldown menu, choose the device that you're using for playback, and adjust the volume.
*   Alternatively, you can open the Volume Mixer by right-clicking the speaker icon located in the lower right of the screen, and choosing "Open Volume Mixer."
Are you using voice communications software?
If you're using voice communications software, the volume of the audio device might be automatically adjusted according to the status of communications.
If so, disable automatic volume adjustment as follows.
In the "Communications" tab, change the setting of the item "When Windows detects communications activity" to "Do nothing."
Part of the playback is wrong: e.g., notes are broken off prematurely, or some notes are lost
Problems may be solved by making the settings shown below.
Try adjusting the audio buffer size of your software
If your software allows you to adjust the audio buffer size, try changing the setting.
Normally, clicks and pops can be eliminated by increasing the buffer size.
Try adjusting the audio buffer size of the driver
If your software does not allow you to adjust the buffer size, or if adjusting the buffer size in your software does not solve the problem, you may be able to solve the problem by changing the driver's audio input/output buffer size.
Try adjusting the buffer size as described in "To change the settings."
Try updating the driver of your display adaptor
You may be able to eliminate clicks and pops by updating the driver for the display adaptor installed in your computer.
Windows Update / Microsoft Update
You may be able to solve the problem by updating your system with "Windows Update" or "Microsoft Update" provided by Microsoft.
Check the power management settings
Open "Control Panel," click "System and Security," and then click "Power Options."
*   If the icon view is selected for the Control Panel, click "Power Options."
In "Select a power plan," choose "High performance."
*   If the "High performance" plan is not shown, click "Show additional plans."
In the High performance area, click "Change plan settings."
Click "Change advanced power settings."
In the Advanced Settings, click the "+" symbol for "Hard Disk," and click the "+"symbol for "Turn off hard disk after" to open it.
Click "Setting (Minutes)," and click the down arrow to change the setting to "Never."
Click [OK] to close the Power Options window.
Close the "Edit Plan Settings" screen.
"Performance Options" settings of System Properties
Open "Control Panel," click "System and Security," and then click "System."
*   If the icon view is selected for the Control Panel, click "System."
At the left, click "Advanced system settings."
*   If you are asked to enter the password of an Administrator account, log on to Windows as a user whose Account Type is Administrator, then perform the settings again.
Click [Settings] of the Performance section, and then click the [Advanced] tab.
Select "Background services," and click [OK].
Click [OK] to close "System Properties."
Do the sample rate settings match?
You must set the sampling frequency that's been specified through the audio settings of the application so it matches the GT-10's sampling frequency.
If the Windows monitoring function is enabled, the input sound might be heard in duplicate (doubled), or a feedback loop (oscillation) might occur.
If so, disable the Windows monitoring function as follows.
In "Recording," select GT-10's "IN," and click "Properties."
Open the "Listen" tab, and clear the check box "Listen to this device."
Click [OK] to close "Properties."
Audio clicks and pops occur in the playback or recording immediately after the system has started up, or immediately after the computer has been woken from a Sleep state
Wait a few moments before you perform playback or recording.
Clicks or pops may occur in the sound if a LAN is operating
Try disabling the LAN in the Device Manager.
Such problems may be solved if you check the "Light Load" check box in the Driver Settings dialog box.
If you wish to modify or verify the settings, use the procedure described in "To change the settings."
*   The modified setting will take effect after you turn the power of the GT-10 on/off. Unless you experience problems, use the unchecked (initial) setting.
Playback or recording is interrupted, and then you cannot resume playback or recording
Was your computer experiencing a heavy processing load?
If your computer was experiencing a heavy processing load while the GT-10 was being used, the GT-10 may no longer operate correctly. If this occurs, stop the playback or recording, then try starting playback or recording over again.
[/i]
Starscream
Holy crackin'!  That's a lot 'o' reading!  Thanks!!  I'm gonna give this a shot tonight.  That Roland wipe-all thing may just do the trick!  Funny you mentioned that cause when I tried to reinstall the driver, it starts, and then a window (belonging to the driver install) comes up saying there's a problem, and to use the uninstall.  I already did that.  Several times.  This is exciting!  Cant wait to get home, thank you!  I'll report back with an update!
Starscream
But....one more thing that I think may be key.  I tried to connect the GT-10 after it wouldn't work on my Vista pc, to a Windows 8.1 machine.  Same thing, even when set to 'standard' in the USB settings.  The other computer didn't even realize a USB connection was made. Zip.  Not even an "oop!  something just got plugged in!"  Zero.
Could that spell bad news?
Re-Read the GT-10 USB Driver installation instructions
QuoteBut....one more thing that I think may be key.  I tried to connect the GT-10 after it wouldn't work on my Vista pc, to a Windows 8.1 machine.  Same thing, even when set to 'standard' in the USB settings.  The other computer didn't even realize a USB connection was made. Zip.  Not even an "oop!  something just got plugged in!"  Zero.
Thats normal - Roland / Boss gear is  NOT "plug & Play"  - you must follow the Boss GT-10  USB driver installation instructions for your specific Operation system Step by Step.
Get the  Boss GT-10 USB Driver for your specific Operation system here
http://www.bossus.com/products/gt-10/downloads/
Download the *.zip file - and expand it into a new folder on your PC, and be absolutely sure to read the "README.HTM" file for step by step installation instructions
Starscream
Excellent.  This is all great stuff.  I wonder what the heck happened? It was working just fine about a month ago, then poof. NO FX FLOORBOARD FOR YOU!
Can't wait to start fresh.  I love this dang GT-10.  I hope it comes back to life, when it comes to USB functionality!
Starscream
P.S.  You guys have been INFINITELY more helpful than that bloody Tribes forum / desert.  Trying to get support from Roland is like trying to baptize a cat in the river.  Good effing luck to ya!  lolz
QuoteP.S.  You guys have been INFINITELY more helpful than that bloody Tribes forum / desert.  Trying to get support from Roland is like trying to baptize a cat in the river.  Good effing luck to ya!  lolz
You are welcome
(tell your friends)
The frustration with the Roland / Boss User experience was the prime motivation to create VGuitarforums
Story of VGuitarForums
https://www.vguitarforums.com/smf/index.php?topic=7912.0
Starscream
Well, judging by the amount of threads, and members, this has been a resounding success!!  Awesome!!
So...I know, I know...no crystal ball or anything, but...is there a chance that the USB port on my GT-10 could be gooched?  No idea how that could happen, I take great care of my gear.  More of a curiosity to if you've ever heard of that happening before...
Sure its possible - but unlikely. Unless USB cable got stepped on, stressing the internal right angle USB Type B jack  and cracked the internal GT-10 PC board
I would be sure you have a new USB 2.0 cable labeled with the code 24/2C ,  and using a computer that has a USB 2.0 port (not a USB 3.0 port), and carefully follow the USB driver instructions
Best USB cables are described here
Choosing the Correct USB Cable for Your Audio/MIDI Hardware Device
https://www.vguitarforums.com/smf/index.php?topic=11086.msg80947#msg80947
I have good luck with these:
Belkin Gold Series 10-Foot Hi-Speed USB 2.0 Cable
http://www.amazon.com/gp/product/B00062UKIY/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
There is a possibility the GT-10 USB port is toasted.
You can also use a USB-Midi device adapter, a good brand one, like the Roland UM-One.
Avoid the cheep USB-Midi devices, as they don't work.
Starscream
Right, so...home now, and using the Roland Driver wipe thing...stay tuned, and cross 'em all.
Starscream
Well, CRAP!  Ran the Roland wipe utility, and look at this.  I'm back at this damn screen.  No matter what I do, it won't uninstall correctly!  What now?
* Get a piece of Tape and cover the GT-10 USB port.
* Get a  Roland UM ONE MKII and use the 5 pin MIDI connections to GT-10 for Gumtowns Floorboard Editing
http://www.roland.com/products/um-one_mk2/
http://www.amazon.com/Roland-UM-ONE-MK2-MIDI-Interface/dp/B00967UN50
Starscream
HAHAHA!  Looks that way...dang.  Thanks all.  I just did a system restore, so one last gasp, here...
One last resort is to try a driver manual install.
In your Windows device manager, with the GT-10 USB connected, look for the "unknown USB device" if it exists.
Take note of the downloaded GT-10 driver file, if it is compressed/zipped, then expand/unzip it to a known folder.
The 'unknown USB device' ( or what ever it may be represented as), check 'update driver' and steer to the GT-10 driver folder to find the .inf file.
It might work..
Starscream
And there's the thing. Hasn't shown up in device manager since this fiasco started. Bollocks!  Like I said, I may as well have inserted a pencil into the usb drive. Zero recognition of anything at all.
So...
The Roland midi to usb cord. Will that work just like the regular usb cord that's all messed up at this point? And I'll be able to use that awesome fx floorboard?
...what a pain this all is. And I thank you all.
Yes..
Just select "UM-One" as the midi I/O device in the editor Preferences/Midi menu.
Starscream
#20
Excellent. Now, to get the driver completely uninstalled. Save another sys restore, seems impossible. Neither the Roland utility or a normal uninstall takes it completely out. When I try to then install it again, it shows that damn problem screen. Joy.
Starscream
#21
Quote from: Starscream on May 10, 2016, 01:50:15 PM
Back to this point.  Frig.  How does one completely remove this bloody driver?
CC Cleaner
Free version has a Windows Registry cleaner and driver remover utility
https://www.piriform.com/ccleaner/download
Starscream
Well, I'm normally not one to do this, but I have thrown in the towel.  I'm wasting more time on this lately than actually playing. Bought the Roland USB / MIDI cable yesterday, drivers installed just fine. Went to install the GT-10 driver and got stuck in that damn "a problem may have occurred" loop.  No matter what I do, delete registry entries, uninstall utility that comes with the driver, Roland Clean All utility, updating the PC, Rebooting a million times, System restores, CCleaner, anything.  Nothing seems to work.  If anyone has any ideas how the blazes to get out of that driver loop it's stuck in, lemme know.  At this point, I'm stumped and give up for now.
For now.
Here's that stupid, rage-inducing godforsaken screen that JUST...KEEPS...HAPPENING!
**serenity now...**
Avoid the GT-10 USB cable connection, use an alternative USB MIDI adapter cable
* If you purchased the genuine Roland UM-ONE MKII
You need to:
1 )  Get a piece of Tape and cover the GT-10 USB port and avoid using it.
2 )  Stop trying to install the the GT-10 USB Driver
3 )  Read the Roland UM-ONE MKII  Manual
http://cdn.roland.com/assets/media/pdf/UM-ONEMK2_e03_W.pdf
4 ) Read the Roland UM-ONE MKII  Addendum and slide the switch on the side of Roland UM ONE MKII to the "COMP" setting
http://cdn.roland.com/assets/media/pdf/UM-ONEmk2_l_iPad_e02_W.pdf
4 )  Since you are on VISTA, you must now Download the Roland UM-ONE MKII USB Driver for VISTA 32/64
http://www.rolandus.com/support/by_product/um-one_mk2/updates_drivers/4961
5) There are Installation instructions for various languages.  Open the "Readme_EN.HTM" file and FOLLOW ALL Roland UM ONE MKII USB MIDI cable USB Driver for VISTA 32/64  Installation INSTRUCTIONS  STEP BY STEP
(see here
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=18125.0;attach=14165
6 ) Do not connect the Roland UM-ONE MKII USB MIDI cable to the computer until prompted by the Roland UM-ONE MKII USB Driver for VISTA 32/64 Installation pop up message (Step 9 above)
7 ) Upon completion of the installing the Roland UM-ONE MKII USB Driver for VISTA 32/64 and physical connection of Roland UM ONE MKII to a USB 2.0 port on your computer, verify you see the UM-ONE MKII as an available  MIDI device by your VISTA Control panel Sound System
8 ) Connect the 5 pin DIN MIDI connections from the Roland UM-ONE MKII to the appropriate MIDI I/O jacks on the GT-10
9 ) Now proceed to launch Gumtown's GT Floorboard editor, but in preference windows assign the  Roland-UM ONE MKII  as the MIDI I/O device.
