Total time logged in
Started by kneagle, September 26, 2015, 02:04:03 PM
kneagle
why does my "time logged in" never change - no matter how often or how long I'm logged in?
kn
(my opinion) the site time counter don't add static things like just looking at a page, rather it counts active moments, like typing responses, or the time it takes to retrieve a page on lookup.
So you can have a page open for days, but the time online does not increment unless there is user action.
kneagle - here are your stats
https://www.vguitarforums.com/smf/index.php?action=profile;area=statistics;u=257
I suspect my activity here "broke" the site's statistical analysis tools
https://www.vguitarforums.com/smf/index.php?action=profile;area=statistics;u=4
Know that 50% of my 2177 posts in the GR-55 Board are simply these words:
Read the GR-55 FAQ
ConstruKction
Quote from: Elantric on September 26, 2015, 04:52:40 PM
Read the GR-55 FAQ
I cannot help but to think that you actually have sticky notes scattered around your desktop with ready-to-copy templates of "Read the ... FAQ", "... Top Things to Know", etc.  ;D
Correct-  I just copy 1st post in my Blog below
Elantric's Tips and Blog: https://www.vguitarforums.com/smf/index.php?topic=6125.0
(It's apparent nobody reads it  - since I must copy portions of it every other day )
kneagle
How does this answer my question? I have been stuck at 1 day 21 hours and 34 minutes for as long as I can remember.
kn
The stats counter is working because you are now at
Total Time Spent Online:1 days, 21 hours and 43 minutes.
Total Posts:75 posts
I noticed you haven't actively posted much for 6 years, so that may be why the stats aren't high and haven't changed much for a while.
If you look at mine
Total Time Spent Online:57 days, 3 hours and 16 minutes.
Total Posts:3463 posts
If you work the stats figures like this
My time on line = 57 days, 3 hours and 16 minutes = 205396 minutes
divide that by the number of posts = 205396/3463 = 59 minutes per post.
Your stats worked the same way are
Total Time Spent Online:1 days, 21 hours and 43 minutes = 4903 minutes
divide that by the number of posts = 4903/75 = 65 minutes per post.
Quite similar results, I can assume the time per post equates (on average) to the amount of reading one does before posting.
True - you've only made 5 posts this year
https://www.vguitarforums.com/smf/index.php?action=profile;area=showposts;u=257
Its takes two to have a conversation  - start making 5 posts a week - and your Log in time stat numbers will rise
rsm
I just stay logged in, I haven't logged out in a few weeks... however, it says at present: Total time logged in: 16 hours and 32 minutes.
If I shouldn't stay logged in, please let me know...I just find it easier to check in when I have a few minutes here and there without logging in/out each time.  So much history and info here I'm trying to absorb...
8)
rsm
bass | guitar | keys | Push
Rickenbacker | Steinberger | Boss | Roland
Using Digital and Solid State by Choice
this only applies to time spent posting  - not browsing
And you only have 38 posts - compared to my 19,334 posts
Gumtown explained our Time logged in Stats meter best here
QuoteThe stats counter is working because you are now at
If you look at mine
Quotethis only applies to time spent posting  - not browsing
As the forum stats both show number of posts and activity per category, I guess browsing is counted as well. As a test, I remembered my total time on my forum stats page and spend some time browsing without posting. After three minutes I checked, and my total time had increased.
I guess 59 minutes per post is quite a high number. I usually type up something in two minutes. Only some posts take more time.
