GR-55 and Roland SH-32
Started by Nuno, May 10, 2015, 07:52:50 AM
Nuno
Hi All,
Have anyone tryed the both toghether? I mean, GR > SH. I bought the sh-32 this week and plug it to the GR and it's wonderfull!!!! I surelly recommend it if you are into synths and wanting a very cool arpeggiator.
http://www.soundonsound.com/sos/may02/articles/rolandsh32.asp
The issue now is to play over different midi channels as each part (patch) uses different midi channels. I assume that I can do it with MONO midi out, where each string is routed to a single midi channel but from a performance point-of view it's not working easily. The best solution would be a patch in the GR using midi channel 1, other patch using midi channel 2, and so on...
Any ideas?
GR-55 Midi channel settings are SYSTEM controlled, so midi channel settings are not included in a patch.
Nuno
