GR-55 - Echo Beach
Started by Ashman, November 24, 2012, 06:38:41 AM
Ashman
Here's my patch for Echo Beach - my first patch post so please be gentle!  Not exactly like the original but hey-ho.
To use the patch make sure the Expression pedal is in the toe position to start.  Play an open A note (5th string) and then press the Ctrl pedal - this should give a sweeping synth.  Play the Echo beach guitar riff over the top of this and switch the Ctrl pedal off at some point when going into the first verse.
Use the Expression pedal in the heel postion to mix an electric organ for some of the verses.
I'll will try and post an mp3 later.
shopstartuk
Hi
Thats really good, how do you know what amp effects to use to get the right sound? How did you know to use Hexa Chorus for example?
For the chorus I added the nice tenor patch seems to work well but as there is only one ctl pedal I had to add it as a separate patch and switch to that.
good work and thanks
Steve
Fender Strat Plus Delux
Fender Tele 60th
Roland GR 55
Ashman
Steve,
Sorry not been around a while.
For this patch it was a case of playing around with the sounds, amps and effects until I was happy that the patch was close enough.  Yes that's right guesswork!
Anyway here's the promised mp3.
