vg-99 stompboxes (for fc-200)
Started by itspennywise, October 27, 2009, 02:24:51 PM
itspennywise
Hi all. Im new to this group.
This is my first pacht for the vg-99.  I've only had it for a week now. Let me know what you think.
This patch is like an old multi pedalboard. We've all used one in the past, at least if you're my age (42) or older.
I use my old FC-200 midi controller in CC-mode (control change).  I use an extra ev-5 on cc #1.
In the assing section you can set up your own midi controller.
On the A chanel there's a Strat or a Tele
On the B chanel there's a LP or a L4
FC-200:
#1               compresor
#2               crunch   (used the poly dist, don't really like it yet)
#3               lead
#4               chorus
#5               pan delay   (ctl tap tempo)
#6               solo switch
#7               octaver
#8               space reverb and delay
#9               wha wha switch
#0               tremelo
bank up        guitar switch
bank down    channel switch
ctl               tap tempo
expression    volume
ev-5            wha pedal
Vg-99:
Control 1    reverb switch
Control 2    reverb level
On the mp3 you'll first hear the guitars (with some rev.) strat, tele, lp ,l4
then the effects in the above order.
I hope you find this usefull. I would love some feedback.
Welcome to the group itspennywise!  :)
I moved you post into the patch section where all posts containing patches should be. Thanks for contributing!
azzurro
Would these port across to the FC300 ok?
itspennywise
In think they would,  if you're in control change mode.
some will work right away because of the same cc number (both expression pedals, cc#7 and cc#1)
others you'll have to manualy change in the vg-99's control assign menu. (i personally use the vg-99 editor)
i hope it works out for you
(english isn't my native language, as you might have guest;-)
