VG-99 - Metallica - Enter Sandman
Started by Elantric, February 10, 2008, 04:26:30 PM
By Andrew Turner.
Made using a GK-3 on an Ibanez with Ebony Fretboard, 10-46 strings, Line In on a Crate Powerblock Amp -> Marshall MG412 cab
http://vg99.webstandards101.org/vg-99.html
Metallica - Master Of Justice
CTRL1 for 4th harmonies (Creeping Death) - CTRL2 for Harmonist (Blackened)
By Andrew Turner.
RushFan
That Enter Sandman patch is really hot by the way. I would have probably included a control for the clean segments and a wah for the solo stuff, but it's still a great tone. Interestingly enough, if I play it with my non-GK Telecaster, it sounds closer to early Metallica.
ZORO
I'm completely unable to open ANY of your patches! Every time I try if reads "unable to open this file". I have an Intell Mac pro. Please help or post so I can load them.
Many Thanks,
ZORO
Launch the VG-99 Editor
ZORO
I've tried it 100 ways.  Just tried with editor launched - "Cannot read files of this type".
Thanks for getting back to me but still not able to open. Any other suggestions ???
ZORO
Quote from: ZORO on November 28, 2008, 01:29:17 PM
ZORO
IMPORT / PATCH and it will not over-write your system settings.
ZORO
I've read where you warned against that.  I've been trying to load that way. I can load everyone's patches but sustainiac's.
ZORO
Quote from: ZORO on November 28, 2008, 01:45:36 PM
ZORO
I added the .mid version. Try those.
ZORO
Thanks!
I was able to open both, but Enter Sandman.mid loaded and there's no sound.  MasterOfjustice.mid sounds really good. If possible if you could give the .mid version of "nye lonn.g9e under acustic, i'd really appreciate it!  Any Idea why it seem I'm the only one who can't load sustainiac's patches?  Do you have any idea why I might not get any sound out of the .mid version of EnterSandman?
Again-Many thanks!
ZORO
ZORO
I did get Enter SandMan to fire up.  Patch volume was off.
ZORO
Quote from: ZORO on November 28, 2008, 02:13:59 PM
ZORO
I'll fix it also.
Quote from: ZORO on November 28, 2008, 02:10:47 PM
ZORO
The .g9e files load with a different command than the .mid files. That is all I can think of is that you were trying to load the same way as the others. I loaded them fine when I created the .mid version.
This one is done.
Thanks for pointing these out. We try to keep these off the board so they don't mess someone's VG up.
ZORO
Glad that got sorted. Actually these are Andrew Turner's Patches  - reposted from an old VG-99 Board.
