VG-99 -Applying VG99 effects to DAW audio
Started by Pingala, May 04, 2013, 04:46:35 PM
Pingala
I'd like to record my guitar clean in Cakewalk Sonar X1 and then apply effects later in the production process, kind of like when I use Guitar Rig 5 effects during the mix. I'm confused by pages 73-5 in the instructions, if that's the right area. Anyone know the correct settings, if this is possible?
read the articles on reamping with VG-99 here
VG-99 Re-Amping Guide
https://www.vguitarforums.com/smf/index.php?topic=93.msg148#msg148ty
http://www.rolandus.com/products/details/849/support/
http://www.boss.info/assets/media/pdf/VG99WS01.pdf
The VG-99's flexible USB routing allows you to record the VG-99's total sound, or record a dry, unprocessed signal to DAW software while monitoring the sound with COSM amps and effects during recording. When it's time to mix, you can play the dry audio back through the VG-99's COSM amps and effects, and then re-record the result on another track. This is a process known as "reamping," and it gives you the ability to adjust guitar sounds to match your needs at mixdown, rather than having to commit to them ahead of time.
The Guitarist's Guide
to Recording on your Computer
Recording Guitars: With Mics, Direct, Amped, Vamped, Re-Amped
http://tweakheadz.com/guitarists-guide-to-recording/
VG-99 Q&A
http://www.boss.info/assets/media/pdf/VG_99_Q_A.pdf
