VG-99 - Steeldrums
Started by ajvdn, March 23, 2008, 10:06:03 AM
ajvdn
I hope you like this patch as much as I do.
It's a steeldrum.
CTL 1 = one octave lower
CTL 2 = echo. (this is actually the second COSM guitar)
Regards,
AJ
G
I cant seem to get this one to work.  No sound is coming out-- anyone else have this problem?
feloniouspunk
Yes, you have to go into the MIXER section and make sure all the volumes are up.  I am not at home right now, but I believe there is a overall patch level that might need to be adjusted. I think it is on page 1 or 2.  Also check your output levels in the MIXER section as well, depending on what type of output you are using- MAIN, SUB, or Digital- these may need to be adjusted.  This should get you  rolling.
check this link.  Somebody else had the problem as well.
https://www.vguitarforums.com/smf/index.php?topic=619.0
Lots of Gear. :)
G
Perfect, that solved it .  Thanks a lot!
This patch is amazing!  Great job!
