stereo horn patch
Started by iamdave, February 24, 2013, 01:33:05 PM
iamdave
Hello all, using a brian moore guitar with a gr55, and am trying to do a stereo horn patch for blues backup etc. Rhythm 07-2 is a rnb horn patch but it's mono. How would I make it stereo?
Are there any cool horn patches here or anywhere that can be downloaded into this also?
Wouldn't mind better organs also with like a draw bar on the pedal. My gr33 had one that seemed better than what I've heard so far on the 55. Thoughts? Am I missing something?
Dave
Dave -
Don't know of a patch offhand.   You could start with 7-2, and experiment with the Chorus stereo settings and/or the Delay stereo settings, see if that gives you what you're looking for.
The 7-2 voice is built up from a couple of PCM voices, a brass & a sax.  You could also simply edit those and pan one slightly right & the other slightly left for a different effect.
If you need help doing these tweaks, just ask!
I had a GR30 and loved the Jazz Organ sound.  I made an attempt to emulate that here:
   https://www.vguitarforums.com/smf/index.php?topic=3336.0
Shawn
Quotewith a gr55, and am trying to do a stereo horn patch for blues backup e
Try here
GR-55 PCB Brass Patches
https://www.vguitarforums.com/smf/index.php?board=125.0
Lots of GR-55 Organ Patches here
https://www.vguitarforums.com/smf/index.php?board=76.0
iamdave
Thanks folks. Hey, one thing I can't seem to find is how you pan things.
I would think I could pan strings on my guitar, or instruments. Some reason I can't find the pan in the settings or throughout the manual.
How do you pan?
Many thanks,
Dave Byers
www.davebyersmusic.com
www.writingsongs.com
www.christiansongwriting.org
www.dcmusicstore.com
This is an overview of the GR-55 Audio Blocks
And a detailed Inspection of the actual Audio Routing.
See page 25 of GR-55 Owners manual for explanation of the PCM 1 /2 Controls - and see that each PCM Tone has a separate "Pan" control.
To Pan Guitar,
Choose the GR-55 Structure with "AMP/MOD", and buried in the MOD Controls is a Pan control for Guitar
See page 42 of GR-55 Owners manual -
Or
Choose the GR-55 Structure with "MFX", and buried in the Controls is a Pan
See page 45 of GR-55 Owners manual -
IMPORTANT GR-55 POINT OF INTEREST.
Understand that anytime you Enable many types of "Stereo Effects" in the MOD or MFX Block, or enable the GR-55's Main "Delay , Reverb, Chorus" effects - you loose your stereo image set by ALL the above Pan Controls.
You must disable GR-55's Main "Delay , Reverb, Chorus" effects  if you want to maintain your Stereo Instrument Pan Assignments set above.
THANK YOU ROLAND  ::)
If you're new to the GR-55, it may not be very obvious that you can scroll down the list of parameters:
From the main screen, hit EDIT.
Select one of the main components (PCM1, PCM2, etc..) & hit ENTER.
Scroll down a bit to see PAN.
(Of course, it's preferable to use Gumtown's editor!)
Elantric's right - the FX have panning settings/variants, and if you select them, you kind of turn over responsibility to panning to the effect.
Shawn
