Using GR-55 in poly mode with Kontakt
Started by tahitianrocker, June 19, 2014, 08:37:52 PM
tahitianrocker
Hello everyone
Here is my problem: I want to play my kontakt library with the gr55 in poly mode and use a CC# assigned on the ctrl switch to change the midi channel and by doing so it will allow me to change the active kontakt library rack.
For example:
In kontakt 5, I load 4 library/synth sounds racks:
1) Scarbee bass on midi ch 1
2) Alicia keys     on midi ch 2
3) Session strings on midi ch 3
4) Modern drummer on midi ch 4
I would like to press the ctrl switch and toggle between each of theses midi channels
so i can play them one at a time on all 6 strings. (And not one instrument rack per string!!!)
Or have the gr55 send what i play on midi channel 1 when i press ctrl switch, midi channel 2 when i press EXP switch, midi ch3 when i press the gk button1, midi ch4 when i press on gk button2.
That way i can play individual racks with all 6 strings live in kontakt standalone mode just by pushing a switch that sends CC# on the GR55.
Is this possible? Have any of you managed to do it? Do i need to learn the multiscript fonction in kontakt?
Thank you for your help.
Sorry but it is not possible, the midi channels in the GR-55 are not assignable to any pedals.
The GR-55 can send on a different midi channel per string, so you could set up Kontakt to have certain instruments play on different strings.
Another way is to use patches, use the GR-55 to change patches of Kontakt instruments per patch (if kontakt supports that)
Also read
Evenharmonic GTAK - switch instruments by playing notes on your fretboard
https://www.vguitarforums.com/smf/index.php?topic=6808.msg47198#msg47198
Midi triggering a VST with the GR-55
https://www.vguitarforums.com/smf/index.php?topic=4465.msg30218#msg30218
3) GTAK provides many useful controls for the MIDI Guitarist,such as selecting different NI Kontact4 voices on different fret ranges of your strings.
See the Video.
http://evenharmonic.com/videos/gtak_overview
