FTP - Controller not found
Started by yuri, February 28, 2015, 02:51:47 PM
yuri
I wonder what I did wrong, I installed everything, but no sign of operation. Controler not found  ::)I know it's boring to you, but I ask for help. Thanks
What type computer?
What OS version?
yuri
yuri
the latest model mac book pro 16GB yosemite
Contact Fishman Support ASAP
Thanks to the new OSX "GateKeeper" You do have to perform a few new tricks to install music apps on OSX Yosemite
http://mac-how-to.wonderhowto.com/how-to/open-third-party-apps-from-unidentified-developers-mac-os-x-0158095/
yuri
Ah yes, I know for this ,  I will be it disabled during software installation - does not work the same .    continues  , Controller not found!
yuri
#6
when ! pressed button at key FTP - everything appears ok, after 3 seconds - again -Controller not found  ???Maybe something with battery?
Spider
Do you have choose audio interface?
Spider
#8
So... has the FTP Controller been  charged for 4-6  hours ?  if not charge it!
contact Fishman
yuri
I try to recheck everything tomorrow, Many thanks !!
Let the FTP Controller charge overnight
yuri
I loaded up all night, it is load. But it does not work, the FTP control panel, does not see anything , again Controller not found! The thing is very frustrating >:(  and to think that I bought Mac book pro, only to use with FTP etc.
yuri
I can not work together  controller and receiver usb key together,....I tried several times schiare  red light  bottons, here is problem !signal does not couple! (softwar not receives nothing).- (Reciever not found ! and Controller not found ! at my panel control FTP) I checked all the rest, all instalations software are all in place. ???
yuri
#13
Video  at you tube    https://www.youtube.com/watch?v=XMnkPjEawiM&feature=youtu.be  I FTP Controller charge overnight and ok . but here  .. I press red button ?? problem is here   https://www.youtube.com/watch?v=tNlFJ3Fsgvk&feature=youtu.be
Spider
Press (not briefly) red button on the receiver AND and on transceiver to !!!
Read the FAQ  about Pairing the new FTP
FTP FAQ
https://www.vguitarforums.com/smf/index.php?topic=8427.0
My TriplePlay controller will not sync with the receiver. How do I get them to pair?
You need to push the button on the receiver, and the small button on the controller. The LED light on the controller is also a button (some people miss this). You need to press this button until the light flashes more quickly (it may require a firm push, especially on the initial attempt after installation) and also press the button on the receiver. When paired, the receiver light stays solidly on, and the controller light flashes more slowly. If this does not work, quit the TriplePlay standalone app, unplug the receiver and turn off the controller. Relaunch the TriplePlay app, plug the receiver back in, turn on the controller, and repeat the pairing process.
- Important! -  read ALL the Separate PDF Docs for TriplePlay
IMPORTANT
You get "receiver not found" if your audio device is not configured or not available.   Setup your audio & try again!
* Check for Stuck Button and controls on your FTP Controller
https://www.vguitarforums.com/smf/index.php?topic=8400.msg60844#msg60844
* FTP Hardware Reset and Force a reload of the FTP firmware Guide.
https://www.vguitarforums.com/smf/index.php?topic=8491.0
For the best installation of the Fishman Tripleplay Pickup - same rules apply as mounting a Roland GK-3 pickup.
* Mount the FTP PU as close to the bridge as possible
* Adjust the FTP PU height so the fretted strings at your highest fret clears the FTP PU by 1 milimeter.
* Set your FTP String sensitivity to the correct range  - see links to all FTP docs below.
Latest FTP  Info and Apps and Docs
(Check here frequently)
http://www.fishman.com/tripleplay/help
http://www.fishman.com/tripleplay/help?platform=Windows%207&version=1.0.2412
Updated FTP User Guide
http://www.fishman.com/software/tripleplay/download/tripleplay_user_guide.pdf
Updated FTP Hardware Guide
http://www.fishman.com/software/tripleplay/download/tripleplay_hwguide.pdf
NEW FTP Training Guides
Tutorial #1: Playing Sounds in TriplePlay
http://www.fishman.com/software/tripleplay/help/tripleplay_tut1.pdf
Tutorial #2: Adding Traditional Guitar Audio
http://www.fishman.com/software/tripleplay/help/tripleplay_tut2.pdf
Tutorial #3: Organizing Sound Patches and Songs
http://www.fishman.com/software/tripleplay/help/tripleplay_tut3.pdf
Tutorial #4: Customizing sounds and patches within the parameter panel
http://www.fishman.com/software/tripleplay/help/tripleplay_tut4.pdf
Tutorial #5: Working with Virtual Instruments
http://www.fishman.com/software/tripleplay/help/tripleplay_tut5.pdf
Tutorial #6: Creating Layers and Splits
http://www.fishman.com/software/tripleplay/help/tripleplay_tut6.pdf
Tutorial #7: Using TriplePlay with a DAW
http://www.fishman.com/software/tripleplay/help/tripleplay_tut7.pdf
Tutorial #8: Using TriplePlay for Music Notation
http://www.fishman.com/software/tripleplay/help/tripleplay_tut8.pdf
Tutorial #9: Using a MIDI Controller Pedal
http://www.fishman.com/software/tripleplay/help/tripleplay_tut9.pdf
Tutorial #10: Adjusting Neck Angle
http://www.fishman.com/software/tripleplay/help/tripleplay_tut10.pdf
yuri
It Works !! Thanks a lot !!
Congratulations!
Continue reading all guides above!
