GR-55 Audio Player and CTL Pedal
Started by randulo, June 27, 2016, 08:32:19 AM
randulo
I guess there's no way to use the audio player AND the CTL pedal in the patch? Am I missing something?
I use the pedal extensively, so that makes the audio player less use full. I'd rather the player used the EXP pedal switch.
I see I'm not the first: https://www.vguitarforums.com/smf/index.php?topic=3261.msg21369#msg21369
I'll see if there's any help in that manual reference. Ok, not that obvious, but the EXP SW can be used. Then you have to turn the player button to off. Cumbersome, but it works.
Hopeful GR-55 convert from GR-1
Twitter @randulo
Medium @randulo
