JTV -Bouzouki
Started by arislaf, October 02, 2013, 01:05:33 PM
arislaf
The greek sounding instrument.
edmaestro
Excellent sound!  Usable as a mandolin too.
arislaf
To be used with helix patch http://line6.com/customtone/tone/2781972/
For those that don't own a helix, set a 10 band EQ wtih 31hz at -15db, 62hz at -15 db, 125hz at -5db, 250hz at -3.4db, 500hz at +0.2db, 1khz at +1db, 2khz at +4db, 4khz at 5.4db, 8khz at 15db
and add a spring reverb  with decay at 2.3 predelay at 42ms, mix at 31%
spemph
I've just recently gotten a Variax standard and discovered the work you've done.  Thank you for your time and effort and for sharing!
The bouzouki helix patch uses an IR.  Is that one of the standard IRs or a custom IR?  Is it needed for the Helix patch to sound correct?
Thanks!
arislaf
Quote from: spemph on February 20, 2019, 03:13:59 PM
Thanks!
Thank you for your comment! The ir was used as a match making, to compare the eq. I just forget to delete the block afterwards, so it is not needed at all. Hope you are enjoying it!
