MIDX-20 compatible USB interface cables (and probably good for other use also)
Started by CodeSmart, August 03, 2017, 09:45:21 AM
CodeSmart
Hi, I've started this thread to produce a list of MIDX-20 (or MIDX-10) compatible (and non compatible) USB-to-MIDI interfaces between the PC and the MIDX for safely setting up the advanced features of the unit and doing firmware updates.
I welcome any MIDX user out there to post here what interface (cable or box) he/she's been using and if it worked or not.
This list is also probably a good indication if the interfaces are good for other use as well, as the MIDX traffic involves fast and rather large SysEx transfers.
List of compatible interfaces (in price order)
TIE Interface 1/10 http://www.tie-products.com/en/product/midi-1i1o/
Price indication: 14 EUR www.thomann.de
Prodipe MIDI 1i10 (also called Thomann Midi USB 1x1http://www.prodipe.co.uk/midi-interfaces/2120-interface-midi-usb-1in-1out.html
Price indication: 15 EUR www.thomann.de
M-Audio MIDIsport 1x1 USB http://www.m-audio.com/products/view/midisport-1x1
Price indication: 29 EUR www.thomann.de
Roland UM-ONE MKII https://www.roland.com/us/products/um-one_mk2/
Price indication: 41 EUR www.thomann.de
iConnect MIDI 1 https://www.iconnectivity.com/products/midi/iconnectmidi1/
Price indication: 59 EUR Bax Music
Native Instruments Komplete Audio 6 Audio/midi interface
Price indication: 233 EUR www.thomann.de
E-MU Midi 2x2
Price indication: Discontinued
List of non compatible interfaces (not working)
PROZOR USB to MIDI Interface (also sold by other names on ebay etc.)
Price indication: $5USD on ebay
Miditech Midlink mini
Rolloq
CodeSmart
Quote from: Rolloq on August 03, 2017, 11:11:39 PM
E-MU MIdi X2x2 discontinued,but works as a charm. ;D
Rolloq
Thank you Rolloq - It's been added to my first post. Also added pictures.
vtgearhead
M-Audio Midisport 1x1.  Inexpensive and works with large sysex payloads as well.
CodeSmart
DanVG
Hello,
I also noticed a problem with the SysEx when controlling my GR-55 by an Arduino and a clone interface of the Prozor (Bespeco BMUSB100) : only the first SysEx passed correctly. I do not know if this is applicable to all cases, but I solved my problem by sending after each SysEx a CrtlChg not recognized by the GR-55.
CodeSmart
Quote from: DanVG on August 06, 2017, 07:45:17 AM
Hello,
I don't intend to even try to make it $5 Prozor compatible. If you buy at junk price, you get junk ;-)
Anyway thanks for the tip  :D
1VL
Just wanted to add my experiences at the right place :
RME Fireface UFX (Discontinued)   works like a charm with big sysex data
ESI M8U XL (Discontinued, but M4U XT is still available) with drivers installed, firmware updates work well
Neusonik iM/One (Discontinued) doesn't work for firmware updates, only for config. with the editor
If you use one of these and any variants which look similar
No-one can help you, these ones only handle keyboard notes, patch change, and a very limited size of sysx data,
and randomly choke up, requiring to be disconnected from the USB port to re-start.
If you use one of these for doing firmware updates, it will be your own fault your updated device is bricked.
I recommend the Roland UM-one first and foremost,
and any Edirol brand (which is owned by Roland).
Some I have used with good results (in other projects)
Edirol UA-20
Edirol UA-25
Edirol UA-101
tsunamizone
spyrl
