GT-001 Patch loading
Started by neilwillford, October 11, 2014, 09:26:06 AM
neilwillford
maybe you can help me with something.  I have a bunch of presets i downloaded but they show up as midi files. how do i convert them to work on my gt001?
Gumtown can answer this, but try the "Import SMF" function on his GT-100 editor.
neilwillford
ok i see import on the librarian but no import wmf? where do i find it?
neilwillford
SMF i meant this dumb spell checker.
You will have to download the GT-001FxFloorBoard editor (I am assuming you have the GT-001), which is currently it is a work in progress, as no-one has been able to reply to me as to whether it works or not.
But if you open the *.mid files in the editor, it should be able to load them into the GT-001FxFloorBoard editor and into the GT-001.
http://sourceforge.net/projects/fxfloorboard/files/GT-001FxFloorBoard/
It will load GT-001/GT-100 Tone Studio *.tsl patches and also GT-10, GT-8, GT-10B, GT-6B, and Boss ME-80 patches.
neilwillford
thank you for your response. i will download it and try it and post again whether it works for the gt001 or how well it works. thanks again.
neilwillford
ok i installed the gtfxfloorboard program and it says my unit isn't a gt001 effects processor and won't connect. i have the newest usb driver installed so i am not sure what the problem is.
neilwillford
#7
Ok i figured out what i was doing wrong with the gtfloorboard software. you have to select gt001 for daw control not the gt001 in the preferences. now it connects fine and works well.  If you try to do things to fast it crashes but as long as you take your time it works awesome.  Fine job to the person who wrote it.
Quoteyou have to select gt001 for daw control not the gt001 in the preferences.
Glad you got it working -
Interesting - as thats opposite what Roland/Boss recommends for Boss GP-10 USB Connectivity with BOSS TONE STUDIO for GP-10.
INSTRUCTIONS FOR BOSS TONE STUDIO for GP-10 (July 2014 ) PDF
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=11879.0;attach=9641
Quote* Select GP-10 , NOT GP-10 DAW CTRL.
* The device can be changed from the SYSTEM.
neilwillford
trying to connect with just the gt001 setting it tells me that my unit isn't a gt001. also i have to have it in debug mode to connect.
yabo
#10
i downloaded the gt-001 floorboard it connects fine but if you go to fast it crashes. i was wondering how do i load the gt-10 factory presets..it only lets me load 1 at a time is there a way to load all presets in at once so i can go through them and pick the ones i want.great job on floorboard boss should let u design all their software..do you have a editor for the br-80 ..thanks
