Roland Japan GP-10 Q & A
Started by Elantric, July 05, 2014, 12:35:45 AM
Its in Japanese here:
http://jp.boss.info/support/by_product/gp-10/knowledge_base/63181417/
And Google English Translation is here:
https://translate.google.com/translate?sl=ja&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.roland.co.jp%2Fsupport%2Farticle%2Findex.cfm%3Fq%3Dfaq%26p%3DGP-10&edit-text=
This info at link above often never gets distributed outside Japan  -
So we VGuitarforums members get a head start!
I know many things can get lost in translation! But its still worth reading.
GP-10 Guitar Processor Q & A
Q. GP-10, Can I use as an audio interface for DAW software?
    A. Can be used.  It is necessary to USB connection on download, you install the GP-10-only driver from the download page.
Q. GP-10, Can I use as a MIDI interface for DAW software?
   A.It can not be used as a MIDI interface.
Q. Can I also use gut guitar nylon string?
  A. It can be used as long as GK guitar equipped with piezo pickup.
      It has been released from the company, such as Godin.
Q. Can I use 12-string guitar and 7-string guitar?
  A. It does not correspond to the 7-string guitar or more.
Q. Are you sure you want to work with GK-2?
  A. You can use a combination of the GP-10 and GK-2.
      Select the "GK-2A" in the Type: GK1 of SYSTEM.
Q. Is it possible to play with the sound of the normal pickup to guitar amp, and the modeling guitar sound to the PA?
  A. You can then output the normal pickup sound from the GUITAR OUT terminal, and outputs only modeling guitar sound from the OUTPUT terminal.
Q. Can I use guitar (with tremolo) arm?
  A. You can use basically, but there is the case (situations) that the size of the case of the bridge arm with guitar is large, there is no space to install the       Dibaidetto (GK-3 hexaphonic)  pickup. Please check in advance.
(Note – basically saying some Floyd Rose guitars lack room for the GK-3)
Q.  Can I use guitar Semiako (Arch Top) type?
   A. Conditions of guitar that can be used are shown below.
      •   From the pick-up center, to (the end of = GK-3) Guitar bottom: up to 280mm
      •   Possible body thickness sandwiched dedicated holder: up to 60mm
        At the same time, please also see attached photo.  , even if it meets the above conditions, depending on the specifications of each guitar, there may be a       problem is not attached pickup, cable length is Trivial, such as guitar, not Hasame dedicated holder.
For more information, please contact the guitar manufacturers.
