Yamaha FC-7 Expression - Re-centering expression pedal?
Started by mos6507, February 05, 2008, 01:28:49 PM
mos6507
Has anyone tried a Yamaha FC-7 with the VG-99?  It has an spring you can put in it so that it automatically pops back to neutral, right?  I was looking for an expression pedal like that as a smoother alternative to the regular expression pedals for virtual whammy and b-bender duty.
Michael Dolan Doubleneck
Les Paul Custom
VG-99
FTP
dead_lizard
Interesting. Makes me want to rig up some springs on the left FC300 pedal.
I already loosened the action on it with some allen keys. It just felt wrong to have a wah as stiff as that.
chipstar
Dude,
Great idea. The expression pedals on the FC300 are too damn tight.
thanks,
Chipstar
drbill
I'd like to have an expression pedal that would re-center itself when I let go of it -- like the wheels on a keyboard do. Anyone seen something like this?
GP-10, KPA
vanceg
The Electro Harmonix Next Step expression pedal returns to a middle position when you take your foot off of it.   Ideal for Whammy control on the VG-99 ;-)
mbenigni
Quote from:  vanceg on September 21, 2014, 01:39:56 PM
Actually, it returns to the toe down position, which is a little bit restrictive.  Cool pedal otherwise.
vanceg
Quote from:  mbenigni on September 22, 2014, 07:05:19 AM
You are absolutely correct. I was wrong in believing that I could set the Calibration so that it would return to more of a "centered" position.  I now use the SoftStep's Pressure Sensitive Buttons for pedal work where I want to return to a center position when I release.
Some older Yamaha FC-7 Expression pedals had a spring return with center position
http://www.guitarcenter.com/Yamaha-FC7-Volume-Pedal-100087438-i1124543.gc
The Yamaha FC7 Volume Pedal is a heavy-duty volume controller with fortissimo function which lets you accent certain parts of a performance. Adjustable pedal angle, spring point adjustment, and a metal connection plate for multiple-pedal ganging add unique capabilities for various playing styles and setups.
Yamaha FC7 Volume Pedal Features:
Heavy-duty construction
Fortissimo function
Spring point adjustment
Metal connection plate for multiple-pedal ganging
5' cable
Single 1/4" TRS plug
Spring center spot  adjustment on bottom
But will require an electronic mod ( Pot Swap to 10K Linear) ) to make it electrically a "clone" of the  Roland EV-5  - which is the type required for VG-99 / FC300 / GP-10 use
I have at least 6 of these in my basament, We use to sell the s**t out of these. Great pedal
vanceg
The FC-7 is a good solution once you put the 10K pot in it.  Right now I'm having a company called Aescher build me a self-centering volume pedal with USB MIDI output specifically for Pitch Bend control of the VG-99. I will report back here how well it works.
