GR-55 - Nylon Guitar - with Nuance
Started by shawnb, February 22, 2013, 04:55:32 PM
All -
Attached is a simple nylon-string guitar patch, which makes use of the nuance feature.  When "nuance" is applied, you will here a dark breathy tone added in.  This is intended to be a very subtle add-on effect, just adding some breadth to the tone when you are playing your most "nuanced"!
When playing, a rapid finger-tip pluck = lower nuance, slower ball-of-finger pluck = higher nuance, & broad side-of-thumb pluck = highest nuance.   Nuance only works when playing with your fingers, it will not apply when using your pick.
More on nuance & its configuration is found here:
https://www.vguitarforums.com/smf/index.php?topic=7929.0
And in the setup information here:
https://www.vguitarforums.com/smf/index.php?topic=6972.0
Let me know if you like this!   I'd also be very interested if anyone else is using Nuance in their patches!
Shawn
Sarge516
The is now my #1 Nylon patch.  Thanks for the post!
Sarge
