FTP + iconnectivity midi 4 + external synth + pitch bend issue
Started by fusion99, August 09, 2017, 02:37:09 AM
fusion99
Hi guys.
I've just bought the iconnectivity midi 4 + in order to use the FTP to control external synth (kurzweil racks). I have this problem. The iconnectivity is control by a Digitech midi control , in order to change the patches on the external synth. I would like to have pitch bend set to 0 , always. I prepared the FTP in harware mode (first patch) in order to have trigger option. First question , it's said "Power Switch On while D-Pad UP Button is engaged", it means with the software on and the USB FTP key already powered up or not because, if I power up the  Tripleplay controller on the guitar it keeps on lighting but the usb receiver does not recognize it.
SEcond question: when I want to change the patches on the external synth (I'm actually using piano and Rhodes tones) often  the pitch bend keeps wotking and it does not have the 0 settings I'd like (which is a real problem). The question is: do I have to fit the Fishman pitch bend trigger or do I have to configure the iconnectivity in order not to have any longer the pitch bend?
I had the same trouble with the gr33 (controlled by FTP + Iconnectivity)
CodeSmart
Have you checked if there's a firmware update for your iConnectivity product?
That could be the problem.
First question:   Yes, HW mode is what you get powering up while pressing the up key - but only if you do NOT have the app running.
For more on the different modes, read this:
https://www.vguitarforums.com/smf/index.php?topic=13653.0
Second question:  You should be able to find a way to stay in trigger mode.   Changing synth patches should not change what your ftp xmits.
If you want to stay in trigger mode all the time, for pianos/keys, my suggestion is to use Basic mode, which allows you to  switch in and out of trig mode using the back & enter keys.
Again, follow the link above to learn about the different modes and how to use them.
fusion99
Problem solved. Thanks a lot Shawn. Useful suggestions!!! Have a nice day guys!!!
