GR-55 - Patch not saving correctly
Started by Spatzi, June 21, 2017, 09:13:36 AM
Spatzi
Created a patch. Tried to save to a user preset, overwriting the old one. Everything saves except the two pcm settings. Never had this happen before. Anyone have any ideas?
Probably a controller switching it on you.
Spatzi
Not sure what that means.
Quote from: Spatzi on June 21, 2017, 10:05:19 AM
It means that you may have a controller switching the parameter that does not save. Like a foot-switch/foot-pedal assigned to change the PCM. https://www.vguitarforums.com/smf/index.php?topic=3868.0
I assume you are using Gumtown's  GR-55 Floorboard Editor?
https://www.vguitarforums.com/smf/index.php?topic=2951.0
GR55 not saving all edits on user patches ( check conflicts in Control Assigns)
https://www.vguitarforums.com/smf/index.php?topic=4548.0
Spatzi
I managed to figure it out. Not using that editor, yet. So far, been able to manage without it.
lespauled
Get the editor.  Makes life much easier.
