Davy Wentzler - Audio Evolution Mobile Studio (IOS)
Started by Elantric, February 22, 2017, 04:06:38 PM
Best Android DAW app is now on iPad
http://www.extreamsd.com/forum/showthread.php?tid=480
QuoteAudio Evolution Mobile is available now for the iPad!
After two years of hard work, porting the Android version to iOS, we are proud to have our multitrack studio app available on all iPads running iOS 8 or higher.
Next to the same functionality of the Android version, the app features support for AudioBus, Inter-App and Audio Unit v3 effects and instruments, document sharing and a web server providing easy access to your projects and samples from other computers.
Audio Evolution Mobile for iOS is a free download. To create more than 3 tracks, add busses or use more than 1 effect per track, an in-app purchase is required.
https://itunes.apple.com/app/apple-store/id1094758623?mt=8
By Davy Wentzler
Description
Record your ideas on the go or create entire music productions from scratch, we'll leave it up to you! This app is a portable multitrack audio and MIDI recording studio featuring virtual instruments, editing with unlimited undo/redo, mixing, real-time effects, automation and much more!
Note that this is our initial release and we'd appreciate any feedback or bug reports! We are highly responsive to customer feedback.
Features:
• Multitrack audio recording / playback
• MIDI sequencing with piano roll editor
• Drum pattern editor
• Inter-app audio effects and instruments
• AudioBus support (including AudioBus remote)
• Audio Unit v3 instruments and effects displayed directly in the app
• Non-linear editing with move, trim, split, cut/copy/paste, remove, cross-fade, etc. with full undo/redo
• Virtual instruments (comes with free instruments and more instrument packs to download with in-app purchase)
• Wide range of downloadable loops available (free and paid)
• Clip volume and fade points
• Loop playback
• Automation of mixer and effect parameters
• Mix-down to WAV, AIFF and ALAC
• Metronome
• Punch in/out
• Zoom down to the sample
• Each track has controls for volume, panning, mute, solo, arm, 3-band EQ with mid-sweep, 3 insert effects, 2 effect sends and output bus selection
• Unlimited number of tracks (more than 3 requires the PRO in-app purchase)
• Unlimited number of groups (requires the PRO in-app purchase)
• Real-time effects including: chorus, compressor, delay, dual delay, reverse delay, reverb, flanger, noise gate and many more!
• Offline effects: fade in/out, normalize, reverse, pitch shift, time stretching
• Several grid options for aligning your samples (with tempo and time signature settings)
• Projects are interchangeable with our Android version
• Export to other DAW's by rendering all tracks to separate audio files (stems)
• Media server to access your files easily from a desktop computer
In short: a complete portable multitrack music studio that will replace your fourtrack recorder or tape machine!
(*) The following in-app purchases are available to expand your studio:
• FX pack 1 (distortion, overdrive, speaker sim, wah wah, phaser)
• FX pack 2 (10-, 15-, 30-band graphic EQ)
• ToneBoosters effect pack 1 (Barricade, DeEsser, Gate, Reverb)
• ToneBoosters EQ with frequency analyzer
• ToneBoosters Compressor
• Vocal Tune with two-voice harmonizer
• Soundfont instrument packs
• Loop packs from Function Loops
If you have any suggestions, questions or want to report a bug, please contact us! We'll gladly solve any problem!
Twitter: http://twitter.com/#!/AudioEvolution5
Facebook: https://www.facebook.com/AudioEvolutionMobile
Forum: http://www.extreamsd.com/forum
Online manual: http://www.audio-evolution.com/manual/doku.php?id=start
Davy Wentzler Web SiteAudio Evolution Mobile Studio Support
What's New in Version 1.1.0
* Added Mono option to mix-down and stems dialog
* IAA FX bug fix
* Solved progress dialog issue in stems dialog
