GR-55- FCB 1010 -> GR-55 MIDI Volume not working - patch change is OK
Started by hineana, May 20, 2017, 10:19:12 AM
hineana
The FCB 1010 is changing patches on the GR-55, but the expression B pedal MIDI volume doesn't affect the GR-55 volume.
As a control, when the FCB 1010 is plugged into a GR-30, the expression B pedal works fine and raises and lowers the GR-30 patch volume.
Is there any way to use an external MIDI expression pedal with the GR-55?
Verify your pedal is sending MIDI CC# 7 to control GR-55 patch volume
Learn to debug MIDI CONTROLLERS
hineana
The FCB is sending CC7, the GR55 is not responding. Does your GR55 respond to MIDI volume? If so, what setting allows that? Assigns are limited to toggles. I'll read its spec, some synths do not use CC7, the GR30 does however.
Try enabling MIDI on GR-55
details
GR-55 Midi Volume Control
https://www.vguitarforums.com/smf/index.php?topic=10890.0
hineana
https://www.vguitarforums.com/smf/index.php?topic=3978.0 had the answer near the bottom. "Toggle" needs to be set to "moment"
assign 1-8
switch on
target patch patch level
target min 0
target max 200
source cc7
source mode moment
act range lo 0
act range hi 127
