godin multiac natural steel
Started by nervoteso, February 16, 2015, 05:19:14 AM
nervoteso
Hi
i've just bought a godin multiac natural steel, very good sounding with gr55, but it is very hard to play for me, does anyone think the same? action is very high, how to set up it? i've tried to install 0.11 instead of 0.12 but then i had a lot of issues, a lot of strings buzzing. so after truss setting now buzzing is gone away but guitar is also more difficult to play.
any suggestion?
gvidelock
Do you mean the Multiac Sprectrum Steel (http://www.godinguitars.com/godinmultspectrump.htm)?
I play the Spectrum Steel for my duo, acoustic gigs. I have to adjust the truss rod seasonally and, thinking back now, I did add a business card thickness (or two) to the neck socket to raise the neck slightly. I find the thickness and width of the neck easy on my hands for a whole night of playing.
I also played a bit with the strings (.011's and .012's) and went back to the recommended Light Jazz set of .012's.
If you don't feel confident in making adjustments you should definitely take it to a luthier to get it better to your liking.
I love the guitar with the GR-55. Adding strings or pads behind the acoustic for songs like Nights In White Satin, Rocket Man,  Turn The Page (among others). I was just listening to a recording I made from the mixer of Walking In Memphis where I used only a piano patch (my playing was a little sketchy, but it still came off okay...I have a great lead singer).
Godin Spectrum SA
Godin Freeway SA
Fender Telecaster with Ghost and Hexpander
Fender Stratocaster with internal GK3 with Synth-Linx
Warmoth custom with internal GK3
Boss SY-1000
Roland GR-55
Roland GP-10
Katana 100W Head
nervoteso
thanks for the suggestions, yes i'll take the guitar to an other luthier cos it is too difficult for me that action. one luthier yesterday told me that he can't do anything cos due to the way the guitar is built, but i'll try with an other luthier.
i love this guitar and the sound it makes with gr55, adding pads or strings to acoustic sounds.
nervoteso
Quote from: gvidelock on February 16, 2015, 06:04:07 AM
no my guitar is another, it's not spectrum, but multiac steel
http://www.godinguitars.com/godinmultsteelsap.htm
kenact
Unless it's an older model, that I'm not familiar with, the only Multiac Steel String with 13 pin is the Spectrum. It is absolutely possible to adjust the guitar to your preference.
Good luck with it.
Danoblaster Baritone w/GK-3
Gretsch Nashville, Viking
Fender Strats
Fret King Supermatic
Larrivee DV03RE
Parker Midi Fly
Seagull, S&P 12
VOX Phantom XII
Sentient 6
Cyr 7
gvidelock
I see some differences in the two models (your Steel SA and my Spectrum SA).
On the Steel it looks like the truss rod adjustment is at the guitar body end of the neck. On the Spectrum it's up at the tuner end of the neck.
I found one picture of the back of the Steel and it looks like the neck attaches in the same way that the Spectrum neck is attached (four bolts).
Good idea to check with another luthier.
Godin Spectrum SA
Godin Freeway SA
Boss SY-1000
Roland GR-55
Roland GP-10
Katana 100W Head
kenact
That's an older model that's been out of their catalog since at least 2012, but it does have an adjustable truss rod, and it can be adjusted much like some of the older Fenders and Danelectros, which also have the adjustment at the body instead of the headstock.
Fender Strats
Larrivee DV03RE
Parker Midi Fly
Seagull, S&P 12
VOX Phantom XII
Sentient 6
Cyr 7
There are a few Steel String Godins that resemble the Multiac. I have a 2014 Godin A10
https://www.vguitarforums.com/smf/index.php?topic=4946.msg98380#msg98380
Many Godins have Bolt on necks that can be adjusted just like a typical bolt on neck Fender. Dramatically change the action by inserting a neck shim.
If your luthier is not capable of shimming the neck on a Fender or Godin, have him search YouTube to learn how, or change Luthiers.
http://www.fishman.com/software/tripleplay/help/tripleplay_tut10.pdf
Godin with Synth Access
http://www.godinguitars.com/godingman.htm
http://www.godinguitars.com/berklee/davidmash.htm
http://www.godinguitars.com/grquickstart.htm
Godin Freeway SA
http://www.godinguitars.com/godinfreewaysap.htm
GodinaThe xtSA
http://www.godinguitars.com/godinxtsap.htm
http://www.musiciansfriend.com/product/Godin-xtSA-Electric-Guitar-with-Synth-Access?sku=511885
Godin LGX-SA AAA Flamed Maple Top Electric Guitar
http://www.godinguitars.com/godinlgxsap.htm
http://www.musiciansfriend.com/product/Godin-LGXSA-AAA-Flamed-Maple-Top-Electric-Guitar?sku=511919
Godin LGXT
http://www.godinguitars.com/godinlgxtp.htm
http://www.godinguitars.com/godin_dStuermer.html
Godin Multiac Steel SA
Godin Multiac Nylon SA
http://www.godinguitars.com/godinmultnylonsap.htm
Godin Multiac Nylon Fretless SA
http://www.godinguitars.com/godinmultnylonfretlessp.htm
Godin Multiac Grand Concert SA
http://www.godinguitars.com/godinmultgrconsap.htm
Godin ACS-SA
http://www.godinguitars.com/godinacsp.htm
Godin ACS-SA Slim
http://www.godinguitars.com/godinacsslimp.htm
Godin Multiac Jazz & Multiac Jazz Spruce
http://www.godinguitars.com/godinjazzp.htm
kenact
Quote from: Elantric on February 16, 2015, 04:05:19 PM
I wish I did. :)
Fender Strats
Larrivee DV03RE
Parker Midi Fly
Seagull, S&P 12
VOX Phantom XII
Sentient 6
Cyr 7
