VG-99 - "MooreLPdualamp" i.t.s.o. G. Moore
Started by rolandvg99, July 06, 2015, 04:47:06 AM
rolandvg99
Another phaser/comb filter patch. Dual channel, slightly different amp settings, delay, solo-switch and OD.
VG-99 controls
Ribbon - pre gain with inverted post gain. More pre gain=less Post gain
CTL1 - AMP solo
CTL2 - OD on/off
FC-300 CTL1 - AMP solo
FC-300 CTL2 - OD on/off
FC-300 EXP1 - wah (with EXP1SW on/off)
FC-300 EXP2 - delay (reversed volume) = Pedal down full delay volume and pedal up 0 volume.
Quick and dirty demo can be found here: MooreLPdualamp.
My little Soundcloud corner
Smash
Finally!! He's back at last.
Great patch  :) I'm having that one.
Smash
Or not...patch will not load - just does nothing  :(
ffata
Same here, File/Import/Standard SMF...in this case into an INIT PATCH in the 99 and nothing happens. :(
Ack!  I need to try it but my time over the next 3 days is so limited.  GACK!  Downloaded.
rolandvg99
#5
Will check and re-upload.
Re-uploaded, just in case.
Btw, couldn't find anything wrong with the first one. It downloaded and installed fine using SMF-import.
Smash
Well there's something wrong cos it won't load and neitehr will the other two you've posted. It doesn't even try to load them - just does nothing. Werird
rolandvg99
