VG-88 - Midi Patch at VG-88
Started by anmegil, February 12, 2013, 07:06:19 AM
anmegil
Hello All.
I am new in this forum and up to now I am truly happy that finally I found more people with VG equipment.
I have a noob question. I have found a patch that supposed to be for VG-88 (from a German site) but it is in midi format.
Is there any way to open it with the Veditor or at least try it directly to my VG-88.
Thanks a lot,
Anmegil (from Greece)
They were obtained here:
http://www.soundsderhelden.de/soundsderhelden.html
They have both PC (Windows)
http://www.soundsderhelden.de/download/VG-88_Sounds_der_Helden.zip
or Mac Versions
http://www.soundsderhelden.de/download/VG-88-SDH-MAC.zip
German Instructions
http://www.soundsderhelden.de/download/VG-88_SDH_Sound-Anleitung.pdf
Translation:
TRANSFER DATA TO THE VG-88
(see manual page 72)
Press 1) The VG-88 [F6] (= system), then [F5] (= MIDI press), then [PAGE>] button until "WAITING ..." in the display.
2) The "MIDI IN" jack on the VG-88 with the "MIDI OUT" socket of a hardware sequencer or PC / Mac computer (with MIDI interface and
Sequencer software) connect via MIDI cables.
3) Play The VG-88 Midi file with the new sounds in hardware sequencer or computer. It may take a moment for the VG-88 in the
Display "RECEIVING ..." displays. After several minutes, the display shows "Idling ...", the charging is completed.
4) [EXIT] key, the display will show "NOW CHECKING SYSTEM PATCH & DATA". After checking the new sounds are on the User
Locations 1.1 to 2.13
IMPORTANT FOR PC USERS
On some PCs, it can sound cards / cable without optocouplers be transmission errors such MIDI Sysex. use
then a PC with real MIDI interface or cable with optocouplers (€ 15, -) or try one of the free updater
Programs on our website www.rolandmusik.de under Service ? Downloads ? Tools ? Updaterproramme (Updater 2)
IMPORTANT FOR ALL
These sounds were programmed for a neutral reinforcement (PA, sound reinforcement system, mixer, tape recorder) - set the OUTPUT SELECT
therefore to "Line / Phones". If you use the VG-88 in combination with a guitar amp, you should use the VG-88 to the RETURN / MAIN
IN the effects loop of the amplifier close - set the OUTPUT SELECT, then "Power Amp + Speaker / return". Nevertheless, it may
come through the amplifier to the speakers of the amplifier to sound coloration.
If your amplifier does not have an effects loop, and the VG-88 on normal input connect, the sounds do not sound original, since
in the VG-88 was used by the modeling amps: VG-88 amp model + real guitar amp = double the sound!
... AND HAVE FUN!
On the next page is a table with the 50 sounds. Have fun rocking and rolling! (Send questions and comments to harnisch@rolandmusik.de)
You may use the free Roland SMF Player application to send the MID file to your VG-88
http://www.roland.com/support/article/?q=downloads&p=VB-99&id=1812766
- but you must use a third party USB to 5 pin MIDI cable
musiclover3
Hello Elantric,
I see that the links are not present anymore at the moment. Where can I find these MID files?
Sincere greetings,
Luc (Belgium)
sadly these are history
Roland Germany deleted them a few years ago
Maybe someone has a backup
find VG-88 patches here:
https://www.vguitarforums.com/smf/index.php?action=downloads;cat=21
