GR-55 - Clean Jazz COSM Guitars
Started by jwhitcomb3, February 02, 2013, 10:36:09 AM
jwhitcomb3
Here are three similar patches. They all use the guitar GR switch to select your guitar's pickups, the COSM, or both. The CTL toggles the amp solo switch. The EXP switch brings in a bass faded across the EAD strings, and a piano with its level controlled by the EXP. The bass and pianos are different on each patch for variety.
The guitars are the L4, the 335 and the P90LP.
I hope you enjoy these as much as I do!
jwhitcomb3
Here they are again, with an edge of grit to them. I forgot to mention above that the EXP pedal (EXP switch off) dials in the reverb level.
