Deal Alert Thread
Started by Elantric, February 17, 2011, 08:40:36 AM
Kokopelli
Add this company to your list of quality cables and quality service. ((Best Price Too))
https://www.advancemcs.com/
Advance MCS Electronics  - 877-349 - 5891
Beats using a screwdriver to chisel a Control cavity
https://www.amazon.com/exec/obidos/ASIN/B0000DEZK4
http://m.bensbargains.com/redirect/dremel-335-01-plunge-router-attachment-17-at-536573/
Just add your Dremel tool. It's plunge router attachment $17
Kokopelli
Here's a simple solution for Headphone Cables. Lapel Size or Normal Size. I purchased from Newegg and it arrived 2 days later. It cost about 4 dollars. I have no affiliation with any vendors. I hope this helps some of you who are bugged by the headphone cable. You can attach it to the back of your shirt or to something off your body if you wish. Cheers!
"  Jabra 0476-219 Wired Clothing Clip "
https://www.newegg.com/Product/Product.aspx?Item=9SIA8N24RV1438&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-
vtgearhead
Quote from: Elantric on April 05, 2017, 03:18:47 PM
Will the bearings on a Dremel survive that degree of side-load?
Quote from: snhirsch on April 22, 2017, 06:39:20 AM
If you use a ball bearing model and work slowly
http://www.pcbgcode.com
This will work like butter in basswood and mahogany
Just remember to wear a mask and don't inhale the dust
Inhaling wood dust can cause of emphysema
https://www.vguitarforums.com/smf/index.php?topic=11656.msg25981#msg25981
DF400
QuoteWill the bearings on a Dremel survive that degree of side-load?
I have one of these and have used it extensively. Although functional for small projects, do not expect it to tackle bigger projects where you need route deep into the surface or cover a large area. Also, your Dremel will overheat and you will put too much stress on the bearing if you attempt to go too fast. In addition, the plunger stop and the guide are understandably not deigned for precision work. That said, it is definitely better than attempting to use a chisel or using a Dremel guided by hand. My one recommendation is to unsure you invest in quality router bits, such as the ones actually made by Dremel. You will blow through the cheap ones fast and they will not cut smoothly.
Papaschtroumpf
Monoprice distortion mini pedal, $9 (regular $40). A few extra bucks for shipping.
https://www.monoprice.com/mobile/product/details/611600
It's actually a decent pedal for classic rock type tones.
mordecai
Good price for my favorite pedal board case
Gator Cases GW-GIGBOXJRPWR Gig-Box Jr. Pedal Board/Guitar Stand Case with Power = $119
https://www.amazon.com/gp/product/B01CWYZVPU/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Save $100 on Variax Standard
other Promos
http://line6.com/promos/
Dom Lockett
Boss Katana Head - UK - £269!
http://www.promenademusic.co.uk/boss-katana-100-head
With free next day delivery too. I couldn't resist!  ;D
FLASH SALE!
Expand your amp and effects collection without breaking the bank. For a short time only, you can save 30% off all Line 6 Model Packs. More amps. More effects. More tones!
Offer ends at 11:59pm (PST) June 12, 2017.
http://store.line6.com/software/model-packs.html
DiscountMags.com has Make: Magazine on sale for $33.95 - $19.46 w/ coupon code 29048 = $14.49 per year (up to 4-Years may be ordered at the per year price).
https://www.discountmags.com/magazine/make?c=61065e08512a11e792bddafb51a005200INT&sdtid=10175992&a=slickdeals
Focusrite iTrack Pocket Portable Stereo Microphone and Guitar Input for iPhone Video Creation and Sharing $19.99 sss eligible @ amazon / OOS but orderable !
https://www.amazon.com/gp/product/B00NB42FTG/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Usually ships within 2 to 5 weeks.
Record quickly and easily. No prior experience required
Make Professional Performances: Look and sound amazing. iTrack Pocket cradles your iPhone at the perfect angle for recording stunning performance videos
Built for the YouTube Performer: Easily master and upload your recording to YouTube using Focusrite's free Impact app
Easily Enhance Your Quality: Built-in high quality stereo microphone and guitar input; use Focusrite's Impact app to find the perfect setting for the clearest possible recording
Officially for iPhone: Supports iPhone 6, iPhone 6 Plus, iPhone 5S, iPhone 5C, iPhone 5 with the included Lightning cable
Its only 16 bits - but clean low noise preamp
$10.99
Compatible to any 9V, negative tip effect pedal power adapters. Absolutely true bypass.
Cute and Portable. 3.5*1.2*1.4 inches size. Make it easy to carry and storage.
Aluminum alloy shell with concise black/green/red color,classic, stable and strong.
3 knobs control the effect, feedback and delay time, easy to setting and control.
Easy to judge. LED indicator shows the working state for your sets.
Features:
1)Portable size: Only ⅔ of small iPhone size.
2)Hard surface:Aluminum alloy provide enough protection for the set.
3)Easy to use: Setting and control the set through 3 knobs.
4)Wide range of application: Can work with any 9v power.
Specification:
1)Delay time:50-400ms
2)Max input/output level: 1.5Vrms
3)Input impedance:150 kohms /  /Output impedance 100 ohms
4)Dimension:3.5*1.2*1.4 inches
5)Weight:133g
https://www.amazon.com/Entil-Concise-Vintage-Analog-Guitar/dp/B01N1IJ2TY?tag=slickdeals&ascsubtag=99de2d1a52d711e78e6e763100633dd80INT
Entil Red 10Keys Kalimba Thumb Piano
Price:   $13.99 & FREE Shipping
Easy to learn , get started quickly
Pushes down on a key with a thumb or finger, and when the key is released, the vibration resonates in the wooden body, making nice sound
Anyone who picks up one of these instruments can make a great sound right away
Smooth surface, nice polish, very beautiful and delicate
Small in size, easy to carry and store
https://www.amazon.com/Entil-10Keys-Kalimba-Thumb-Piano/dp/B071L6MPY5/ref=lp_13665102011_1_12?srs=13665102011&ie=UTF8&qid=1497647343&sr=8-12
GuitarBuilder
50% off on Melodica [amazon.com]if you want to get yourself or your kids trained on piano style melodica.. Use code: LG84A64X at checkout to get 50% off ($17.98 total)
Best Deal.37 key are wider than 32 key in the range, there are three sounds across octaves
Two playing modes:Standing performance and Sitting performance
Products of the keys and the body are used food grade ABS non-toxic engineering resin,much healthier and safer
Suitable for instrumental music teaching, music playing, music learning
Includes: 37 Key Melodica,Mouthpiece,Extension Hose,Cleaning Cloth and Black Zipper Case(Plus hard and Compressive)
https://www.amazon.com/dp/B06WGVLQC5/ref=sr_1_13?s=musical-instruments&ie=UTF8&sr=1-13&keywords=melodica​ [amazon.com]
https://www.amazon.com/dp/B06WGVLQC5/ref=sr_1_13?tag=slickdeals&ascsubtag=e7b56d0855e511e7b6c1aeddf160804c0INT&s=musical-instruments&ie=UTF8&sr=1-13&keywords=melodica
Fishman Tripleplay plug & play Piano Module  - now $150
M-Audio Accent Stage Piano Module with USB MIDI Hosting
PRODUCT HIGHLIGHTS
20 Built-In Voices
5-Pin DIN MIDI and USB MIDI Ports
2x TRS 1/4" Line-Level Outputs
1/4" Headphone Output
The Accent Stage Piano Module with USB MIDI Hosting from M-Audio turns any standalone MIDI controller into a stage piano. It can be utilized without a laptop computer and easily connects to any USB or 5-pin MIDI controller for applications such as recordings, live stage, theater, rehearsals, and more.
Featuring 20 built-in voices, the compact module has the ability to split or layer two voices simultaneously, and includes AIR Steinway Piano and AIR Structure VST instrument samples. There is a 1/4" headphone output for silent practicing, and two 1/4" TRS line-level outputs for connecting to any professional PA system or recording setup.
USB MIDI hosting-when connected via USB, it powers and communicates with the controller
Connect any USB MIDI or 5-Pin MIDI controller to create music without the need for a laptop
20 built-in voices with the ability to split or layer up to three voices simultaneously
Includes AIR Steinway Piano and AIR Structure samples
https://www.bhphotovideo.com/c/product/1218366-REG/m_audio_accent_module_accent_stage_piano_module.html/?ap=y&c3api=0272%2C198944523294&gclid=CJrc-7v9zdQCFUVhfgodQM0Aiw
