GR-55 - how to get the normal pickup in the looper
Started by nervoteso, October 20, 2014, 04:53:14 AM
nervoteso
Hello
i' would like to have normal guitar in the looper how can i do? if i record something i only listen to sinth even if i've abled normal pu.
this is my connection:
guitar - connected 13 pin to roland us20, this one connected to gr55 and to roland gr-d overdrive pedal (i don't use it as overdrive, i use only the guitar output, because i thinks his guitar output is better then the gr55 one); i use guitar output from gr-d to get into my pedalboard ring that end to a digitech looper; from the looper outputs i go into 2 sr jam 100 inputs. also from the gr55 putputs i go into other 2 jam 100 inputs (it is a acoustic amp with more mixer inputs). so i use 2 inputs on each amp. is it a good connection?
my guitar is a xsta godin. i mix  normal pick up and modelling with his controls. for recoording guitar loops i use digitech looper, for looping sinth i use gr55 but how can i have both? maybe gettin into left and right input of digitech looper (1 output of gr55 and guitar out)?
Read the GR-55 FAQ -
The GR-55 FAQ thread is a must read
and learn how to enable the Normal PU
* How to enable "Normal Guitar Pickups" and make the GK-3 Guitar/Mix/Synth three-way switch work with the GR-55:
* GR-55 Documentation Library
https://www.vguitarforums.com/smf/index.php?topic=2953.0
Download and Read ALL GR-55 Setup docs here - these are only available here at VGuitarForums and developed by our members
