IK Irig Power Bridge
Started by Elantric, January 22, 2015, 10:19:01 AM
http://www.ikmultimedia.com/products/irigpowerbridge/
iRig PowerBridge - The first universal charging solution for all iPhone, iPad and iPod touch digital iRig accessories
iRig PowerBridge
Never run out of juice
Introducing iRig PowerBridge, a continuous charging system for iPhone, iPad and iPod touch and digital iRig accessories. Featuring an ultra-low noise audiophile grade power conditioner, comprehensive connection options and other advanced features, it's the easiest way to plug-in and keep your iOS device charged while practicing or performing with your favorite 30-pin or Lightning compatible digital IK gear.
iRig PowerBridge
Features
Allows continuous use and charging of an iOS device and digital iRig accessory
Separate versions available for Lightning or 30-pin devices
Works with iRig accessories with Mini-DIN and Micro-USB ports
Ultra-low noise audiophile-grade power conditioner
Status LED indicates when device is charging
A streamlined solution
iRig PowerBridge combines a power supply and an ultra-low noise audiophile-grade power conditioner that connects to a power outlet on one end and a Lightning or 30-pin iPhone, iPad or iPod touch on the other. Between both ends is a female Mini-DIN connector that can be used to connect any digital iRig accessory with a Mini-DIN or Micro-USB port. Through this connection, iRig PowerBridge allows continuous charging while also passing along audio and MIDI information between the digital iRig accessory and the iPhone, iPad or iPod touch.
iRig PoweBridge
Through this streamlined setup, now you can keep your iPhone, iPad or iPod touch charged and play with your favorite digital iRig accessories and powerful IK apps for as long as you want, no matter whether you're performing on stage, recording in the studio or just jamming at home. It's the perfect complement to powerful hardware accessories like IK's iRig Mic HD, iRig Keys, iRig Pro, iRig HD, iRig Pads and iRig MIDI 2.
iRig PoweBridge
Effortless portability, intuitive use
iRig PowerBridge has been designed with portability in mind. It sports a lightweight and compact enclosure that you can easily carry with you in your gig bag of choice. Available as either a 30-pin or Lightning version, it connects quickly for use and features a LED that provides at-a-glance visual feedback while charging.
