FTP used with high gain amps - any noise?
Started by GeePeeAxe, May 21, 2014, 01:30:30 AM
GeePeeAxe
Planning to buy an FTP this year I have a question about the noise amount coming from the FTP.
If you record high gain sounds and midi simoultaneously, does the FTP produce much noise?
I ask it because my Axon AX50 produces much noise in such recordings.
Is there a way to avoid it?
Thnx in advance
Djordje
QuoteIf you record high gain sounds and midi simoultaneously, does the FTP produce much noise?
FTP generates  zero noise anomalies.
Resulting Audio Noise will be a direct result of the quality of your Computer  / iPad  Audio Interface and Instrument preamp, and Guitar pickups (single coil Mag PU's are the worst)   and properly adjusted settings.
I have excellent results using Focusright Audio/MIDI, Line-6 Sonic Port VX, Boss GP-10 as Audio Interfaces
