Sustain pedal question
Started by Cez Nov, May 01, 2014, 06:09:31 AM
Cez Nov
Hi!
I have a problem with pedal in FTP software. It is a pedal attached to M-Audio Axiom Pro keyboard. When I play sounds in Synth channels it works ok, although the Sustain diode is not flashing. But in pedal channel it doesn't works at all... what may be the problem?
Verify that the MIDi channels match up
Use a third party MIDI Monitor app to verify exactly what MIDI data your FTP host PC/Mac is receiving when you press the Sustain Pedal on your M-Audio Axiom Pro keyboard
More info on debugging MIDI Controllers is here
Cez Nov
Seems to be fine:
Sustain pedal on: B0 40 7F
Sustain pedal off: B0 40 00
So what may be the problem?
Cez Nov
Ok I got it know. It accept CC#66 msg, not CC#64. I had to change it in my keyboard preferences. Unfortunately now the FTP works ok, but the piano doesn't, because it treats the message as sustenuto not sustain...
