GR-55 - Chaining effects for individual patch
Started by scrutinizer, October 16, 2017, 04:04:27 PM
scrutinizer
Hi Guys,
I would like to create a patch on the GR 55 with both a Overdrive Distortion, Phaser "and" a Compressor.  Is that even possible?  Looks like I can only choose two of the three here?  If the following helps.....Right now, this is what I have "MOD  :01  OD/DS"  and  "MFX  :03  Phaser"   I would like to include a compressor in the chain now...possible?
Life would be a whole lot more fun if I had more money!
Quote from: scrutinizer on October 16, 2017, 04:04:27 PM
Hi Guys,
Not that I'm aware of - the GR-55 is a bit of a jack of all trades, and master of none  - and presents severe limitations for many folks
Guitars with Roland 24 pin or GK 13 pin output transmit 6 separate analog audio streams, one per string.
https://www.vguitarforums.com/smf/index.php?topic=14088.0
http://roland.com/V-Guitar/about.html
The GR-55 does many things, but it has a finite number of effects, and limited FX routing capabilities  -
Fast track for anyone to  understand all the possible GR-55 FX options  download
Gumtowns GR-55 Floorboard Editor
https://www.vguitarforums.com/smf/index.php?topic=2951.0
and Help file
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=2953.0;attach=5643
concordal
@scrutinizer, you could try adjusting the gain setting on your virtual amp to get a distortion effect.  That would then allow for phaser and compression to be set up in the MOD and MFX sections.
HTH.
scrutinizer
Quote from: concordal on October 16, 2017, 07:46:46 PM
HTH.
Thanks concordal.  I will give that a shot.
