Roland US 20 Switchproblem
Started by sautersongs, June 04, 2017, 04:38:24 AM
sautersongs
Hello!
I use a Roland US 20 Switch to work with my VG88 and GR55. VG 88 is Channel A, GR 55 is B. Most of the time I use my orginal PU from my PRS Custom 24 to play the guitarsound with my VG88. The Problem is, when I have my GK PU on Mix and I choose Channel B, I still hear the normal Guitarsound from the VG 88. Is there a opportunity to really split the two signals? Normaly,when I select channel B, there should be only the synth sound, not the sound from VG88.  Does anyone have a solution for this, or is there anywhere a swichter which can do really split the two signals?
Thanks for any help!
Greetings from Belgium
Heiko
Read the US-20 switch problem thread
https://www.vguitarforums.com/smf/index.php?topic=2246.0
sautersongs
Hi!
thanks for the link! My english is not so good, so if I understand it right, there is no opportunity to mute my Guitarsingal from my original PU when I use the US 20? Is there any other switchbox which can really switch between A, B and Both?
thanks Heiko
