Hand Job Hot Hand 3
Started by Hurricane, May 15, 2017, 07:29:56 PM
Hurricane
 ;D
Anyone have one ?
I was after an expression pedal for my T.C.Helicon VL3X when I found this unit .
Hand Jobs jobs anyone ?  :o :
And the USB ;
http://www.sourceaudio.net/products/hothand/hothand3.php
This sucker can trigger midi events in a DAW - Midi triggered stage lighting - FX - besides do the expression control pedal duties of whaw whaw ,
flanger etcetera on your ax .
XYZ control parameters in real time via DAW - an left to right panning . Wild huh ! Live you only get the usual up and down pedal type control but with
IMHO more of a dynamic flare and form to function .
Both units together are about what you would throw down for a decent expression pedal .
I'll be test driving this sucker - - I'm cool about it for the guitars - it's quite a departure
from tradition , a departure that IMHO was inevitable .
I am really chillin thinking on how this expands the expressions a electrified harp looses
when slapped uptight against a bullet mic to get that " compression " going that electrified harp has .
You loose the natural hand made whaw whaw when going electrified harp .
The midi control over my Godin LGXSA into my Roland  GR33 into my DAW is going to be interesting
as well . That XYZ and the fantastic Reverbs - Flangers - Delays of the Roland and T.C.Helicon VL3X as well
as what the software synths have are going galactic man , I'm headed for Alpha Centauri !
That hand jive gestures that you make while using the HH3 is a cool theatrical showmanship move  ;D .
Most people ( average types ) never really take notice of a whammy pedal when employed , you can't
miss a hand gesture with this unit or the sound it actives as you do it .
These things about how you will look on stage using this are cool to me as a performer , but YMMV  8) .
EZ :
HR
chopsuey
FYI, the price for the USB version dropped down to 49$/59€. I could no longer resist and got mine delivered today. After the first hours of playing I really like this thing. So far, I have tried effects processing with the TE Op-1 which gives some interesting options. Tomorrow I will try to use it with the GP-10 and see how that works out.
Only thing I did not fully understand until now is how exactly the Z-Axis is supposed to work.
Hurricane
8)
Quote from: chopsuey on July 22, 2017, 11:00:23 AM
;D
chopsuey :
When I saw they had a direct order form the Source audio website I tried to use it but it had issues -
I called them and was able to get both the USB & Base St. with one ring shipped for $125.00 - yes this is quite a bargain .
The Z axis would be a 180/360 degree stationary move more or less .
Just got a Focusrite Scarlwett 6i6 interface for my computer and will try and figure out how to get this to control  the DAW
editing like this :
Check out the panning it does , Iike that .
EZ :
HR[/font]
