Boss Katana Amps - FAQ
Started by Elantric, September 09, 2016, 08:50:43 PM
gustavz
i did not find any informations to the USB settings in the BTS. These are mine. I don't know how to use it. Any ideas please?
Quote from: gustavz on July 27, 2017, 07:10:36 AM
What is your issue?
You adjust these to suite your task
Some of these settings are better explained in the Boss GT-100 Manuals
https://www.vguitarforums.com/smf/index.php?topic=14011.0
gustavz
my issue is, that i like to understand. Your link helped, thanks a lot!
Katana Firmware 2.01
and
Tone Studio 2
https://www.boss.info/global/products/katana-100/downloads/
Read the details in the new Katana 2 Manual
https://static.roland.com/assets/media/pdf/KATANA_e02_W.pdf
And the new Katana 2 Supplementary Manual
https://static.roland.com/assets/media/pdf/KTN-v2_leaf_eng01_W.pdf
and updated Katana Parameter Guide
https://static.roland.com/assets/media/pdf/BTS_KATANA_eng02_W.pdf
https://www.thegearpage.net/board/index.php?posts/24977759/
Gumtown wrote>
QuoteYes, highly recommended.
The only down side for me is FxFloorBoard does not work under version 2, because the patch size is now soooo much bigger,
and for good reason too.
A heap of new effects,
a new and extra/separate "Delay2" including the retro Boss SDE-3000 delay unit.
EVH Flanger and Phaser 90 added to MOD and FX
Send/Return loop with adjustable levels per channel.
Katana 100 now has 8 channels, Katana 50 has 4 channels.
A new separate Equaliser unit.
A new Global EQ
Output Select options called "Air Feel" (live/recording options)
Extensive midi program change and midi CC# control options and GAFC pedal assign options.
FxFloorBoard has some updating to do.... stay tuned folks :)
As always - try the new Boss Studio for Katana 2.0 in "offline" mode to explore all the new features and FX
How to tell the version
Please check the version of the system working on your KATANA before downloading the archive file.
1.Turn the POWER switch on while holding down the [ TAP ] button.
2.If the indicators light up as described below, the system is at the latest version.
For KATANA-100, KATANA-100/212, or KATANA-HEAD
•When the [ POWER CONTROL ] switch is adjusted to "0.5W," the indicator for "DELAY/FX" lights up.
•When the [ POWER CONTROL ] switch is adjusted to "100W," the indicator for "REVERB" lights up.
For KATANA-50
•When the [ POWER CONTROL ] switch is adjusted to "50W," the indicator for "REVERB" lights up.
If the indicators light up in a different way than just described, perform an update.
3.When you have finished verifying the version, turn off the power.
* Don't perform the update if the product is already up-to-date.
Getting the update file
Please open/extract the downloaded "katana_sys_v201.zip" file on your computer to get the two update files named "ROMINFO.TXT" and "KATANARM.BIN" in the "katana_sys_v201" folder.
Procedure for the update
Caution •You must not rename the extracted files.
•Never turn off the KATANA's power while the update is in progress. Otherwise the system program or the KATANA itself may be destroyed.
Please install the extracted system program files into your KATANA according to the following procedure.
1.Adjust the [ MASTER ] knob to minimum.
* Do not connect the KATANA and the computer yet.
2.Turn the POWER switch on while holding down both the [ CH1 ] and [ PANEL ] Tone Setting buttons.
The indicators for the [CH1] ~ [CH4] buttons flash.
3.Connect the computer to the KATANA's USB port by a USB cable.
The indicators for the [CH1] through [CH2]/[CH4] buttons stop flashing and stay lighted, and a "BOSS_KATANA" drive appears on the computer screen.
4.Open the BOSS_KATANA icon.
"Removable Disk (*:)" may appear instead of the BOSS_KATANA icon.
5.Copy (drag and drop) all the files included in the "katana_sys_v201" folder into the "BOSS_KATANA" icon.
* Do not copy the "katana_sys_v201" folder.
6.Disconnect the BOSS_KATANA from the computer.
With Windows 10 / Windows 8.1 / Windows 7
Right-click on the "BOSS_KATANA" icon in My Computer (or the "Removable Disk (*:)" icon) and execute "Eject."
With Mac OS
Drag the "BOSS_KATANA" icon to the Trash icon in the Dock.
7.Disconnect the USB cable.
The [PANEL] button flashes.
8.Press [ PANEL ] button to start the update process.
While the update is in progress, the "EFFECTS" indicators light up.
9.When the update has finished, the "EFFECTS" indicators slowly flash simultaneously.
10.Turn the KATANA power off.
This completes the update operation. The new system program runs at the next startup.
Follow the procedure for verifying the version to verify that the version has been updated.
New Global EQ
New Patch EQ
and New Line Out  controls
External "Show Control" computer or external MIDI Foot controller can now directly access and control on/off state of many Katana built in FX in real time at the gig using MIDI CC# messages to control Katana FX Targets
Quote from: a1terrier, post: 24981085, member: 57133Thanks Elantric
Will I lose the update if I do a reset?
NO
QuoteAnother question where is the cab sim?
try the new Boss Studio for Katana 2.0  to explore all the new features and FX
Quote from: slinkyoz, post: 24982335, member: 122977Any Mac users having trouble getting the new BTS to recognise your updated Katana 100 under High Sierra?
Sounds like a world of hurt on multiple levels
Perhaps you missed the message about NOT upgrading to High Sierra just yet
I suspect the hurdle is lack of "High Sierra" USB Drivers for Katana
https://www.boss.info/global/support/support_news/1709261013b/
Added to the Katana Firmware 2.01 is the Roland SDE-3000
Mr Yoshi Ikegami invented it
http://www.vai.com/roland/
https://www.thegearpage.net/board/index.php?posts/25048232/
VOX me baby, VOX me all night long!
I've been exploring the various sneaky amps and wasn't very impressed with the default tone of VOX model. Kinda woofy, no clarity, and none of the sparkle that I would hope a VOX clean would offer... I kinda ignored it, and went on to other amps that sounded good right away with a minimum of tweaking. Marshall 1959's, Matchless, Marshall JCM 800 all have a place on my presets now with great dialed in sounds.
Today, I heard the guys from That Pedal Show do a whole show on the VOX AC 15 and I loved the sounds they were getting, especially the clean tones. I wanted that! So back to the VOX model on the Katana with a new determination to dial something in if I could. It took a while, but I found the "secret". Much like the real VOX amps have unusual tone stacks that aren't like many other amps... the Katana VOX models also were quite different from the others. The first big clue... I was trying to get more sparkle, so normally I would turn the presence control up... when I did that, it got muddier... so... turned the presence all the way off... voila... here was some sparkly tone! Again, normally to highlight the treble, I would cut the mids... but on this model, it was boosting the mids that did it. So, presence at 0, mids 100%, bass at 10, and treble at 80 ended up being a very, very good clean tone with all the sparkle and clarity I was looking for. Jumping into the eq settings, I bumped the high and cut the mids a smidge. So far, it's my new go to clean channel.
These settings would be radical on any other model, imho... but it shows the capability of the Katana to dial in tones that are far from the norm. YMMV.
https://www.thegearpage.net/board/index.php?posts/25047372/
Mattaraja wrote>
Heads up regarding the Delay2 function and the tap tempo: If you have two delays running, the tap tempo will only work on Delay 1. However, if you turn the Delay1 off (I'm using the GA-FC), then the tap function starts working on Delay2. If you are good with your foot, you can get two different synced delays going, but it takes a specific workflow. This functionality can also get in the way if you use Delay2 as a doubler (e.g. 50ms) and like to pre-tap your tempo before engaging Delay1: your doubling setting will start to sync to the tap and you will have to click out of the patch and back in again to reset the stored delay times. Also, note that there is a second page in the editor for the SDE-3000: look for the the little 1 2 boxes to the right of the new EQ NS S/R buttons.
rolandvg99
Quote from: admsustainiac on October 17, 2017, 11:12:44 AM
Mattaraja wrote>
You can switch easily between tapping DLY1 or DLY2 by long-pressing the tap button on either the amp or the GA-FC.
My little Soundcloud corner
CodeSmart
Quote from: rolandvg99 on October 17, 2017, 11:54:12 AM
FWIW: For those with a MIDX-20, they will be able to control both Tap tempos individually by connecting a dual footswitch to one of the MIDX CTRL jacks (and setting it up properly), or control the taps individually from an external controller (there are two separate CC's for the taps).
vtgearhead
That's interesting.  Did Roland document this or is it something you discovered?  Is there any feedback to indicate when it's changed state?
Use Boss Katana Knowledge Base
https://www.boss.info/us/support/knowledge_base/
Quotealp said: ↑
Do you play with a band? How can you change your preset at the right time when you need to hold a switch for 1 second?
On the other hand, what if you need to let's say jump from 1A to 2B instantly. Hold a switch for a second, then hit B!? IMO, the procedure for changing banks is unacceptable for anyone who plays paid gigs.
If you are using the GA-FC, a footswitch (sold separately: FS-5U) is connected to the
rear panel VOLUME jack or the FX jack, you can use it to
instantly switch between BANK A and BANK B.
https://www.vguitarforums.com/smf/index.php?topic=21996.0
Quote from: rkharper, post: 25121560, member: 179637oh I see, havent had a look at the MT-2 Modell on BTS, thought it has all the controls. I guess you could emulate something with the parametric Equalizer in front of the MT-2, if you so desire.
Metal Zone Controls in Boss Tone Studio for Katana
Anyone can  download Boss Tone Studio for Katana and explore all Katana FX
Run BTS in Offline mode - and you can explore all settings - even without owning the Katana
Important read for all Katanaa users  - see the updated Katana Parameter Guide -
I use a small Windows Laptop with touchscreen
GPD Pocket
https://www.windowscentral.com/gpd-pocket-review
But look for sales on laptops here - MS Surface 3 10.8" Windows touchscreen tablet PC's are recently going for $235 -make a decent Boss Tone Studio controller for last minute tweaks at soundcheck
https://slickdeals.net/deals/computers/
https://bensbargains.com/bargain/microsoft-surface-3-64gb-windows-10-8-tablet-560925/
Katana Firmware 2.02 out now
https://www.boss.info/us/support/by_product/katana-100/updates_drivers/4b233e0e-e986-494f-9e1f-11ee766679b4/
Update history
[ Ver.2.02 ] NOV 2017
Bug Fixes
When TONE SETTING is set to "PANEL," after using the GA-FC (foot controller) to set respective effects to "OFF" and then again selecting "PANEL," the respective effects return to "ON."
Selecting a TONE SETTING for which EQ is set to "OFF" yields sound for which EQ is set to "ON."
When a MIDI Program Change message and Control Change message are received simultaneously, the Control Change message is not applied.
When the unit is updated to version 2.01, all TONE SETTING Program Change numbers are set to "1." (This occurs when updating from version 1 to version 2.01.)
* Use BOSS TONE STUDIO for KATANA Version 2 to set the Program Change number for each TONE SETTING.
When the unit is updated to version 2.01, the SEND/RETURN values for BANK A and "PANEL" are set to "OFF." (This occurs when updating from version 1 to version 2.01.)
* Use BOSS TONE STUDIO for KATANA Version 2 to set SEND/RETURN to "ON."
[ Ver.2.01 ] OCT 2017
Additional Functions
Please refer to the "KATANA Owner's Manual" for detailed information in the [ Owner's Manuals ].
To make settings for added functions, use BOSS TONE STUDIO for KATANA Version 2.
A function to switch between BANK A/B has been added to TONE SETTING.
Please refer to the "KATANA Series Version 2 Supplementary Manual" for detailed information in the [ Owner's Manuals ].
"LINE OUT AIR FEEL" and "CABINET RESONANCE" were added.
"PHASE 90E" and "FLANGER 117E" were added to TYPE for MOD/FX.
"SDE-3000" was added to DELAY TYPE.
DELAY2, EQ (PATCH EQ), and GLOBAL EQ effect modules were added.
SEND/RETURN is now settable for each individual TONE SETTING value.
Setting the PC and CC numbers received by MIDI is now possible.
[ Ver.1.02 ] OCT 2016
Functionality Improvements
Support for BOSS TONE STUDIO for KATANA was added.
Noise when switching effects was reduced.
Bug Fix
The following bug was fixed.
No sound produced immediately after making a USB connection.
https://www.roland.com/us/support/knowledge_base/115002255326/
KATANA: BOSS TONE STUDIOS - HOW TO MONITOR AUDIO PLAYER WITH SPEAKER
Tags: Boss Tone Studios, Primary, Audio Input Output, Speaker, KATANA, Audio Player, Monitor
KATANA: BOSS TONE STUDIOS - How to Monitor Player with Speaker
If you'd like to monitor the BOSS TONE STUDIOS audio Player through your KATANA speaker rather than the HEADPHONE OUTPUT.
In BOSS TONE STUDIOS, located in the bottom right of the user interface there is a SYSTEM TAB.
Click SYSTEM TAB - select DEVICE - select DETAIL - set the following:
MIDI IN: KATANA
MIDI OUT: KATANA
AUDIO IN:
Change from PRIMARY(KATANA) to SECONDARY (KATANA)
AUDIO OUT: leave empty
PRESS OK - the CONNECTION WINDOW will then re-open/appear - then select and PRESS CLOSE.
Now return to the PLAYER and push PLAY on the TRACK you'd like to monitor or hear through the KATANA SPEAKER. NOTE: Make sure the KATANA AMP MASTER VOLUME is set low before pressing PLAY.
https://www.vguitarforums.com/smf/index.php?topic=22094.msg159748;topicseen#msg159748
This 600 page TGP Boss Katana thread should break over 1,000,000 views in the next 24 hours
https://www.thegearpage.net/board/index.php?threads/boss-katana-amplifiers.1744135/page-599
Quote from: PlexiFuzz, post: 25732957, member: 6380Just double checking: is the cabinet resonance control on the Artist functionally the same thing as what we have access to in BTS for the regular katanas?
Yes
QuoteYeah, I was confused by the way things were labeled in BTS. I thought that it was both a) air feel and b) cabinet resonance specifically for the line out and cab sim.
I didn't realize until seeing the Artist discussed that the might be for the actual amp itself. I just messed with it and, though subtle, I really like Vintage vs the default Modern setting. Sounds more natural to me.
https://www.boss.info/us/products/katana-100_212/downloads/
BTS 2.1:
Update history
[ Ver.2.1.0 ] 2018/01
Support for KATANA-Artist was added.
FW 2.04:
Update history [ Ver.2.04 ] JAN 2018
Bug Fix
When the POSITION value for GLOBAL EQ has been set using BOSS TONE STUDIO, the setting is sometimes not correctly applied to the audio.
[ Ver.2.03 ]
Bug Fixes
When switching between BANK A and B using a FS-5U unit connected to the EXP PEDAL jack on the GA-FC, in extremely rare cases, no sound is produced.
When pressing and holding TAP on the GA-FC to switch between setting either the DELAY or DELAY2 delay time, the indicator on the GA-FC sometimes fails to flash.
KATANA ARTIST OWNERS MANUAL
https://www.boss.info/global/support/by_product/katana-artist/owners_manuals/
Read the new common Owners manual
https://static.roland.com/assets/media/pdf/KATANA_eng03_W.pdf
Roland mentions the MIDI commands for Head and Artist  - but Ive checked the Katana 50 and Katana 100 combos with a MIDI Monitor and can confirm the combos  support these same MIDI commands using MIDI over USB
worth trying with older Katana - AFTER loading latest firmware 2.04
Ilgrigio
Hello, I have an Imac with OS sierra 10.12.6, I updated to BTS 2.1 but when I go to see the version is 2.0 .... is it normal?
