SY-300 - Expression Pedal Connection to Boss SY-300
Started by funkyguitar, January 07, 2016, 02:27:46 AM
funkyguitar
I am having trouble getting the expression pedal to function with the Boss SY-300 Guitar Synthesizer unit.  I followed all the steps in this post (for example), regarding using the pedal as a volume pedal:  http://www.bossus.com/support/knowledge_base/205983405
But was unable to get it to work.  The literature is scant in the manual as far as a step by step process to get it working.  I'm using a Mission Engineering EP-1 pedal (confirmed compatible match with the Roland EV-5).  Any help would be much appreciated!
Have a tech check the Mission pedal
You must use a 1/4" TRS Cable
Rumor is the Mission EP-1 is missing the crucial "Ring" contact on the TRS cable connection required for Roland/Boss gear.
More here
https://www.vguitarforums.com/smf/index.php?topic=33.0
BBach
I'm also having trouble getting the SY-300 to respond to an expression pedal. I've tried both an EV-5 and an EHX 8step cv sequencer. Both pedals work perfectly with other units.Both units are connected with TRS.
BBach
So I'm wondering if there is some setting that I haven't picked up on that needs to be changed in order for the expression pedal to work. I assign the parameter to be controlled the same way I assign the control pedals, midi cc, or internal wave function( all of which function as you would expect ). The expression pedal is assigned to patch rather than global control. I'm stumped.
BBACH,
Post your problem SY-300 patch so others may help debug  your expression pedal assignment.
BBach
I'm presently away for the weekend, but will post next week, but the problem is on all patches.
JRR
Hi, i'm trying to set my boss fv 500L as an exp pedal on my boss sy 300, i followed the instructions, but it doesn't work. Does anyone can help me please!!!
Quote from: JRR on March 28, 2018, 09:47:44 AM
Read SY-300 Parameter Guide - page 16 thru 20
if that makes no sense then Read  how all Boss multi-fx use Expression pedals with their requisite concept of control assignments and effects targets
Learn to Program Roland/Boss MultiFX Processors
External Expression Pedals / External CTL Pedals
Roland FV-500H/FV-500L Volume pedals can work as Expression pedals
FC-500H manual
https://static.roland.com/assets/media/pdf/FV-500H_OM.pdf
Must use a TRS cable
"To use the FV-500H/L as an expression pedal, you will need an optional connection cable (stereo 1/4" TRS phone plugs at both ends)."
Nicolher
Thanks, this post made my day !
I didn't have the requested cable at home so used a stereo mini jack + 2 adapters :-)
Now, I can play with my new toy without having to shop for a stupid cable  8)
Interestingly, the FV500 works like a charm with a regular jack hooked to the Line 6 HX effects
Can't find a calibration for expression pedal on SY-300.
Is it hiding from me or isn't there one.
Mine is used primarily for FV and it's "leaking" a bit.
It's working with other units such as AD-10 and VG-99
It's an Boss ev-5
Quote from: Brak(E)man on October 22, 2019, 08:36:38 AM
It's an Boss ev-5
Correct - Like most Roland/Boss gear, the  Boss SY-300 must use an Expression pedal with a linear taper 10K pot ( Roland EV-5 compatible) only
and there is no External Pedal Calibration
Quote from: admin on October 22, 2019, 08:55:38 AM
NoahB
I am having the same problem. Trs two different expression pedals 1 fender old generic and another boss fv 500L. Followed directions no luck. Wondering though someone on one of these mentioned using stereo phone plugs. Is this really what you are using those who are not having problems? Thanks
Jeff beck strat, GandL custom classic semi-hollow bluesboy tele,  mesa roadster, sy300 thru pair of peavey 15d powered pa speakers, big pedal board full of stuff.
On FV-300-L ,
It will not work
must use a TRS cable with the FV-500-L or EV-5
More details here
NoahB
#16
Quote from: admin on September 24, 2022, 04:01:19 PMOn FV-300-L ,
It will not work
More details here
I did miss speak I tried today the Boss FV-500H and trs with no luck. It was the big boss pedal with the option to be expression or volume.
NoahB
It will not work
More details here
I just watched a video on the ev-10 and it said the volume knob on the pedal has to be set to what you want then minimum to be so maybe this is also true for the FV-500H. I didn't buy it so I can't test now but I heard no change when using it. And the fender expression pedal isn't on the list in the link you sent so maybe I have just made both mistakes. I will try tomorrow to test the fV-500H with volume knob in mind. Fingers crossed
You will need to setup up some sort of control assign to use the pedal as it will not do much in the SY-300 "out of the box".
A stereo (TRS) cable is required between the FV-500 pedal (EXP Out) and the SY-300 EXP/CTRL input, a normal mono guitar patch cable will not work.
NoahB
Quote from: gumtown on September 24, 2022, 11:13:48 PMYou will need to setup up some sort of control assign to use the pedal as it will not do much in the SY-300 "out of the box".
I have used a TRS cable not a guitar patch cable. And I followed the instructions to set the device to exp. Assign 1 target to output mixer and the and the parameter to synth volume. I also tried setting the mode to system or patch and neither made a difference. I will see if by chance I had the volume knob on 10 and maybe that was the problem. I will report back tomorrow.
the little knob on the side is for 'zeroing' the EXP pedal range, so no matter where it sits, the EXXP pedal should make some difference to your synth volume.
Is the assign actually enabled (switched on)?
NoahB
Quote from: gumtown on September 25, 2022, 03:47:29 AMthe little knob on the side is for 'zeroing' the EXP pedal range, so no matter where it sits, the EXXP pedal should make some difference to your synth volume.
yes assignment is on. I'm on my way in now we're I can test the volume pot on the side of the FV-500 and if that doesn't do it then there is likely something wrong with my sy300.
NoahB
OK final conclusions: FV-500H does nothing unless it's set all the way to min. Even a smidgen off from that and the pedal does nothing. But I'm happy to say it is working with it set to min. Thanks for your help. Hope this helps others.
udarnick
#23
What I want to do with the expression pedal is to manipulate vst's in Reaper.  Am I able to do that?  I have not been successful yet.  I am using SY-300 with EV-5. I am also using Midi Guitar 2.
In the System/Midi/EXP settings,
setup a midi cc# number to send the exp pedal data on.
