Terrasoniq Ploytec PL2 Micro Duophonic Digital & Analog Synthesizer Module
Started by admin, April 27, 2015, 11:36:03 AM
http://www.ploytec.com/pl2/
http://www.ploytec.com/pl2/manual.pdf
http://www.amazon.com/Terrasoniq-Ploytec-Duophonic-Digital-Synthesizer/dp/B00H4EYBGY/ref=sr_1_1?s=musical-instruments&ie=UTF8&qid=1430159336&sr=1-1
The Terrasoniq Ploytec PL2 generates an enormous variety of sounds with the help of two square wave (pulse) oscillators which can be interconnected in variable and innovative ways - these are fun to experiment with. Not only the classic waveforms such as saw-, sine- or pulse-waves will be simulated, rather newly and interesting sounds - from warm to destructive - are also generated.
http://rekkerd.org/ploytec-releases-v2-1-firmware-update-for-%CF%80%CE%BB%C2%B2-%CF%80%CE%BB%C2%B2-leukos-synthesizers/
Ploytec releases V2.1 firmware update for ??² & ??² Leukos synthesizers
newsApr 17, 2015 0
Ploytec pl2_leukos
Ploytec has introduced a version 2.1 firmware update for its ??² MIDI- and ??² Leukos USB-powered, super-small footprint, software editing-enabled duophonic synthesizers at Musikmesse 2015, January 15-18 in Frankfurt, Germany.
Extended operation comes courtesy of a free software editor for Mac and PC — perfect for sending realtime tweaks to/from ??² or ??² Leukos as MIDI CC (Continuous Controller) messages. Modules onscreen offer even easier user interaction with ??² or ??² Leukos while future features can conveniently be integrated into ??² or ??² Leukos by updating the firmware.
Which brings us neatly to the here and now... now, for instance, it is possible to assign all 128 MIDI controllers to ??² and ??² Leukos' currently-available controllers, courtesy of firmware V2.1. Users can conveniently save, load, and also share them with others. Other notable advances include HQF (High-Quality Filter) mode, doubling the digital filter's resolution, resulting in a higher quality sound experience; Legato Playing possible — if 'note priority' is set and program is monophonic then the lowest key triggers when holding down multiple keys and only the highest one will trigger the ADSR envelope attack phase again upon releasing further keys; even when portamento is switched off, it is now possible to activate it for a single note with MIDI Portamento Control — portamento time is used for the glide effect; when no MIDI clock is available, it is now possible to select one of 12 different default speeds for ??² and ??² Leukos' respective internal clocks and also store the value, together with MIDI channel, note limit, and startup program. Speaking of which, two new presets — both benefitting from HQF mode enhancements — replace the originals stored in ROM (Read-Only Memory) while leaving the 32 user presets unchanged.
??² and ??² Leukos are available for 99 EUR each.
More information: Ploytec
https://www.youtube.com/channel/UCQgH7sJtlog7hdx5Ci7mJLQ
